Help! How can I paint scratch on my bumper?
Old Jul 23, 2015 | 01:43 PM
ennyedison's Avatar
MBZ C250
Guys, I'm driving a C250. My bumper got a scratch. It's kind of deep but not really twisting the bumper. I'm thinking of paint it by myself.... Anyone had some experience?? Need your help. Thanks!!!
Old Jul 23, 2015 | 02:50 PM
socal400's Avatar
MB C400, MB E320, Chevy Avalanche
If the scratch is only on the clear coat, use the 3M scratch remover, it works. Just need to do abit of sanding and buffing, I had reservations at first but did it on my Wifes 2015 C-class and am happy with the results.
Old Jul 23, 2015 | 04:19 PM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
I have used Chipex to great effect to produce an "invisible" repair on several cars, now. On a Citroen, which had a multitude of chips and marks, the largest hole on the colour coat (ie down to primer coat) was 8mm across.
Providing your mark is in the paintwork and not a gouge in the plastic form, then you will achieve a fully acceptable finish.
It takes time and effort, but well worth it.
Old Jul 25, 2015 | 11:40 PM
dnice-1's Avatar
C300 4Matic
You have a pic of the scratch? This would help in determining the best way to repair it
Old Jul 27, 2015 | 03:40 AM
benzw205's Avatar
benzw205
Yes please show it to help to find a solution. We all feel for you
Old Jul 27, 2015 | 05:21 PM
Glyn M Ruck's Avatar
Super Moderator
If it is right through the paint it is easily spot repaired with the Glasurit water based base coat & low VOC clearcoat. They don't have to respray the bumper. As long as you give them the paint code from the doorjam sticker the match will be perfect. Any good small dent repair shop should turn you around in an hour.
Old Jul 28, 2015 | 01:12 PM
ennyedison's Avatar
MBZ C250
Hi guys!! Thanks for the reply! Here is the scratch on my bumper. I bought a touch up paint pen on amazon. Not sure if it;s going to work. I bought this one:
Amazon.com: 2014 Mercedes-Benz C-Class Polar White 149/9149 Touch Up Paint Pen Kit - Original Factory OEM Automotive Paint - Color Match Guaranteed: Automotive Amazon.com: 2014 Mercedes-Benz C-Class Polar White 149/9149 Touch Up Paint Pen Kit - Original Factory OEM Automotive Paint - Color Match Guaranteed: Automotive
Anyone has any experience? Thanks!
Old Jul 28, 2015 | 03:57 PM
ennyedison's Avatar
MBZ C250
Help me please~~~
Old Jul 28, 2015 | 04:37 PM
jolt8631's Avatar
Sorry to be a Jonah, on this but, I have experience of several similar touch up kits (including MB and BMW OEM kits). The fact is that you WILL still see the repair. The reason being that while the colour may match, you will still see the outline of the mark, because the paint level will not be completely flat. The outcome being you will still see the mark, but "coloured in".
As I said in an earlier post, I have had some greater success with Chipex - the difference being when you apply the paint, you "blend" it into the existing surface, by "melting" the newly applied paint, to give you a completely flat finish - after a few coats.. Looking at the damage, I am certain you will achieve a near on invisible repair, using this system.
Up to you my friend, I wish you every success, however you approach it.
Old Jul 28, 2015 | 08:06 PM
dnice-1's Avatar
C300 4Matic
If you got the kit already give it a shot. I'd recommend sanding it down so the scratch is flat and no loose paint then apply the touch up paint let it set then with a high grit sandpaper wet sand it down you will probably need to repeat the process with a couple coats and a couple rounds of sanding once it's to your satisfaction a little rubbing compound then polish then wax. This should hide it where barely noticeable (at least from 3 feet away). Work slow and steady
Good luck! Let us know how it turns out
Old Jul 28, 2015 | 09:26 PM
PeterUbers's Avatar
Originally Posted by ennyedison
Help me please~~~
Here Is some great advice, take it to a good body shop and let them do it the right way.
Old Jul 29, 2015 | 04:26 PM
True101's Avatar
2015 MB Sprinter RV
From the picture, it seems to be a black overrun, you can safely try removing it with simple WD40 oil. You will have to rub it in few times.
Old Jul 29, 2015 | 04:39 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Looks to me more like the paint has been removed down to the plastic. In which case I'd have it professionally sprayed/blended in as a DIY job will look just that, DIY.
Old Aug 1, 2015 | 03:34 PM
Super Moderator
See my Glasurit post. That needs a spot spray repair. See my old C240 & tell me where its been touched. Done by Dent Magic Cape Town in one hour for a knock worse than yours at a cost of $60.
Old Aug 3, 2015 | 02:43 PM
ennyedison's Avatar
MBZ C250
Wow!! That looks good. I tried the finish paint. It's totally a waste of money. I will just go to a local body shop
