Where is the oil drain plug on C300?
Old Aug 17, 2015 | 04:05 PM
bartola's Avatar
CLA-250, C-300
I was all set to change the oil on my C300 yesterday. I first changed the oil on my wifes CLA-250 and was done in like 15 min. (same engine).
So I pulled the C300 and was stumped, maybe going blind - I could not find the drain plug anywhere. I searched the forums, web, dark web and nothing. Manual only had instructions to add oil (pg. 256). Grrr .
Does anyone know where the oil drain plug is located? Pics would be appreciated.
Old Aug 17, 2015 | 11:58 PM
bartola's Avatar
CLA-250, C-300
Has anyone else attempted to change their own oil?.
Vic, will pm you, but if you see this can you post the location? much appreciated.
Old Nov 16, 2015 | 01:21 AM
bartola's Avatar
CLA-250, C-300
By now somebody must know where the drain plug is, google is stupid when it comes to searching cards, all w205 return w204 pics and info.
Old Nov 16, 2015 | 11:08 AM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
You have to remove the plastic shroud under the engine. App. 8 bolts. It will then be obvious.
Old Nov 17, 2015 | 06:48 PM
bartola's Avatar
CLA-250, C-300
Too much hassle, got an extractor.
Old Nov 18, 2015 | 12:12 PM
mikbar2's Avatar
I like to remove the shroud so I can inspect for leakage or anything else that"s obvious.
Old Nov 18, 2015 | 12:59 PM
MASSC450's Avatar
2026 GLE 53 Coupe
Yes, many times...since I was a teenager.
Old Dec 28, 2015 | 04:39 PM
miketc's Avatar
W205
For US model C300 4-banger, the oil drain plug is a 13mm nut facing the front driver side wheel. It is located near the center of the middle plastic shroud with 8mm bolts from the front of the car and near the middle of the engine. Do not need to remove any other shrouds (in front or behind the engine). A 27mm wrench is needed to remove the oil filter cover from the top of the engine. Sorry didn't take any photos when I did it yesterday.
Old Dec 29, 2015 | 09:37 PM
bartola's Avatar
CLA-250, C-300
Thank you sir.
Old Dec 31, 2015 | 04:26 PM
miketc's Avatar
W205
You are welcome; Happy New Year.
Old Dec 31, 2015 | 05:43 PM
DBOC205's Avatar
W205 C250BT
Probably a little late .. but if it helps, the MB doco calls for oil to be sucked out (see attached).
File Type: pdf
Old Jan 2, 2016 | 09:20 PM
miketc's Avatar
W205
That's the instructions to the techs at the dealer. It's fine to drain it from the bottom as well. Thanks.
