2015 C400 Engine Noise at 1500-2000rpm
Old Aug 26, 2015 | 12:17 PM
W205C400's Avatar
2015 C400
I've been experiencing a subtle but noticeable rattling sound when accelerating in my C400 around 1500-2000rpm.
Just crossed the 1500km mark and took it into the dealer. Had a tech ride along with me for a couple blocks and he said it was just the direct injection system.
Has anyone else been experiencing this? Is it really just the direct injection?
Found this post in the tech talk forum (https://mbworld.org/forums/mercedes-...ine-noise.html) about the same issue and thought I would create a thread here as well.
Old Aug 26, 2015 | 12:18 PM
c4004matic's Avatar
17 E43; 21 GLS580
Got a Vid?
Old Aug 26, 2015 | 07:42 PM
heyjoe's Avatar
2015 C400
Yes, I have this noise
My C400 suffers from the the faint pinging noise described here and in the other thread.
My dealer duplicated it, consulted with MBUSA, and it was diagnosed as loose rods actuating the wastegates. Both turbos and both wastegates were replaced, but the noise, while less frequent, still exists. It may be octane related because it appears to come and go with different fill-ups. The dealer now states that the sound is part of the design of the turbo V6 and there is nothing that can be done.
It sounds like a very quiet type of detonation to me. I'm glad others have posted on this because I was starting to think I was the only one, and would get no further action.
Old Aug 27, 2015 | 12:38 AM
W205C400's Avatar
2015 C400
Thanks heyjoe. Good to know I'm not going crazy and it really is an odd sound.
c4004matic, I tried to make a vid. Not sure well it turned out. The audio could be better but it's harder than I thought to drive and film. I've found it's easier to hear the rattle with headphones.
Here's the vid link on vimeo: https://vimeo.com/137447932
Really short 6 second clip with the rattle between the 2 and 4 second mark.
Old Aug 27, 2015 | 03:09 AM
RTX's Avatar
RTX
2015, W205, C 220 BlueTEC AMG Line
At what gear(s) are you experiencing this?
Old Aug 27, 2015 | 07:30 AM
W205C400's Avatar
2015 C400
I mostly notice it at gears 4 and up.
Old Aug 27, 2015 | 08:34 AM
rc400's Avatar
2015 C400
That's the exact sound I'm experiencing starting at 1500rpm and dies down a little after 2000rpm.
Is your car a late build c400?
Old Aug 27, 2015 | 08:51 AM
c4004matic's Avatar
17 E43; 21 GLS580
I hear little rumble at the begging of the vid. I have no idea what it is. Unfortunately the nature of these small noises is frustration since my guess it does it when it wants to and the owner is the one who is attuned to it. I would let it go, if its something bad , sooner or later something obvious will happen then its repair time
Old Aug 27, 2015 | 12:09 PM
W205C400's Avatar
2015 C400
Yeah. It was built in late July.
Old Aug 27, 2015 | 12:11 PM
W205C400's Avatar
2015 C400
Thanks. Probably good advice. The warranty covers me for a few years so I guess I should just enjoy the car and let MB cover any issues when they arise.
Old Aug 27, 2015 | 12:29 PM
rc400's Avatar
2015 C400
Me too, I suspect only the late builds are affected.
Old Nov 27, 2019 | 11:58 PM
BenzWay's Avatar
E400 GLE350 C63
I own an e400 2016 March build with the same pinging noise at idle and rattling sound from the turbos when accelerating. Anyone experience problems yet or hoping it’s normal as my warranty end in under a year
Old Dec 1, 2019 | 08:34 PM
C400Benzeno's Avatar
C400
I have the same noises on my C400. Dealer replaced a couple items, both noises still occur. Now the dealership said those are "normal operating sounds".....
Old Dec 2, 2019 | 02:34 PM
GringoBling's Avatar
C400
C400 here, no sounds like that
Old Dec 3, 2019 | 09:40 PM
BenzWay's Avatar
E400 GLE350 C63
do you have an idea what the dealer replaced? I think this noise might just be related to the turbo wastegate
Old Dec 5, 2019 | 11:40 PM
allanyeung99's Avatar
2017 Mercedes C63s
I had a similar sound, turned out to be a missing nut/bolt under the driver side and it would start to vibrate at cruising rpms. I also had a catalylic converter rattling sound, but I replaced it with a catless downpipe since I was going to tune it anyways.
