New BMS burger tuning for my c400!
Old Oct 31, 2015 | 01:12 AM
rc400's Avatar
2015 C400
I was looking at getting a tune for my car, but then decided on a piggy back system from burger tuning Instead mostly because it was a lease and I can simply remove the module anytime before bringing it in for service and it won't store any codes in the ECU!
So here are my thoughts on it:
When I first installed it, I felt a better acceleration overall but
Mostly on 1/4 to 3/4 throttle was when I felt it made the biggest difference.
At full throttle it's very difficult to tell the difference unless you're timing your acceleration times.
However, I decided to write about it when I felt a huge difference after removing it. The car now feels slow, I got used to the responsiveness and fast acceleration with little throttle.
And even when I give about 1/2-3/4 throttle, the car feels sluggish now.
I removed it because I'm taking my car to the dealer next week to get my winter tires installed and just in case the open the hood, I don't want to give them an excuse to deny any warranty work in the future!
I'm probably going to put it back in the spring since during the winter it's rare I push the car, or maybe sooner since now I got the taste of it and it sucks going back to stock!
Old Oct 31, 2015 | 02:00 PM
TopGun32's Avatar
Congrats
Try map 2. If you have access to higher octane or e85 add 3 gallons.
Map 2 advances timing a bit and higher end is improved.
This engine is a low rev torque boosted engine design for family sedans and SUVs. From day one i knew this engine will not have top end pull... It would take intake, down pipes to explore higher end power. The engine has tiny airboxes and restricted exhaust.
But so far on tuning alone.. Car produces good gains, so plenty left for more.
I took my car to fletjer jones Ontario w bms piggy back for 10k service. No isues.
Old Oct 31, 2015 | 03:08 PM
rc400's Avatar
2015 C400
Hey Topgun,
Unfortunately I don't have acces to e85 here, I'm in Quebec and the best I can get is shell 91.
Well there is the 94oct from Petro Canada but it's mostly detergents.
You're right about the air intakes, I noticed how thin and restrictive
they are, my 2012 c300 had bigger air ducts!
I noticed the extra power when I installed it 2 weeks ago but I noticed even more when I took it out yesterday, I feel my car sluggish now without it! Lol
Hopefully they will come out with updates in the near future that I can use for stage1 with even more power !
I wanted to try my car with and without the stage1 on a drag strip but they closed due to the cold weather and they will reopen in spring.
I will take my car to the drag strip when they reopen and post the 1/4 mile times for stock vs Stage1, I'm very curious to see the results.
Have you tested your car yet?
Old Oct 31, 2015 | 03:18 PM
rc400's Avatar
2015 C400
I also wanted to mention that the v6 engine with the piggy back feels more responsive almost like the 4cyl turbo of the c300.
I got the tune because to me the c400 felt a little heavy and the engine didn't respond as quickly as the 300 I drove a few times, but now that is no more of an issue!
Definitely worth the money!
I can only imagine how the car would feel with a proper ECU tune on a dyno.
(But on a 39 month lease, an ECU tune is not worth in my opinion).
Old Oct 31, 2015 | 05:37 PM
okay.w0w's Avatar
none
Thanks for the quick write up. Might be buying soon too
Old Nov 1, 2015 | 04:45 AM
rc400's Avatar
2015 C400
I'm sure you won't regret it!
Old Nov 2, 2015 | 03:14 PM
Jurzeykid's Avatar
2015 C400
Hey RC,
Questions about the tune because I've been debating that exact 1 (if you've seen some of my posts)
1. Can you turn on and off the power through the entertainment console or is it just always on once installed?
2. Have you notice the MPG with it on? Casual driving? Agressive?
-just stock my gas mileage is turning out to be horrible
Old Nov 2, 2015 | 08:17 PM
rc400's Avatar
2015 C400
Hey Jerzeykid!
Once you install it, it's always on.
You can unplug it, but there's no on/off switch.
As far as gas mileage, I haven't noticed a difference but that wasn't my concern.
If it does make a difference, I doubt it would be much though because if it was significant, it would've caught my attention.
Old Nov 3, 2015 | 11:55 AM
Jurzeykid's Avatar
2015 C400
Hey Jerzeykid!
Thanks RC very helpful!
Right now gas doesnt bother me since im paying 2.25G for 93 oct but if it ever does rebound i may feel differently
Old Aug 30, 2016 | 01:44 PM
Mickav6's Avatar
C63 W204
RC400' I'm in quebec too (je parle Français aussi) and i try the Map2 yesterday.. the car respond very well even on 91oct, you can also try it to see.. do you have some Baseline time for your car at the strip?
Old Aug 31, 2016 | 11:00 AM
JoeyB Benz's Avatar
2018 C63 AMG & 2017 C43 AMG
I went 12.7 @ 108 in my C400 BMS Tuned!
Old Aug 31, 2016 | 11:54 AM
Mickav6's Avatar
C63 W204
map 1 or 2 ??
Old Aug 31, 2016 | 11:56 AM
JoeyB Benz's Avatar
Originally Posted by Mickav6
map 1 or 2 ??
Map 1... 93 Pump Gas.
Old Aug 31, 2016 | 01:07 PM
Mickav6's Avatar
C63 W204
can't wait to see some timeslip with the map2!!
Old Sep 2, 2016 | 03:09 PM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
Will BMS piggyback w/93octane run ok on map 2? Was thinking about this on my way to work today.
Old Sep 2, 2016 | 03:15 PM
Mickav6's Avatar
C63 W204
mine is running on 91oct.. running fine good bump in power! need to do a log tho.. just to be sure it's ok
Old Sep 2, 2016 | 04:50 PM
JoeyB Benz's Avatar
I was Told Map 2 needs E85 Mix. I have not run Map 2. Only Map 1
Old Sep 6, 2016 | 11:37 AM
TopGun32's Avatar
map 2 is for pump gas. With 93 is perfect
i use 3 gls of e85 to mitigate so cal heat and boost goes up another pound or so.
