Panormaic roof seals creaking as temp goes down
Old Dec 7, 2015 | 09:20 AM
topsider's Avatar
2015 C300 Sport 4MATIC
Has anyone else noticed that their panny roof seals creak as the temperature gets lower outside as you are driving down the road? It starts at about 55F and below..
Old Dec 7, 2015 | 10:46 AM
Gungaslow's Avatar
2017 C43 sedan
Mine do... Along with the front dash and rear passenger door and driver b pillar
Old Dec 7, 2015 | 02:33 PM
topsider's Avatar
yeah my dash has a rattle too, sounds like its coming from where the airbag is. I had one in my comand screen and they lined the inside with felt and now its fine. my rear driver door has one too. its too bad the service intervals are so far apart from eachother, because if i bring it in for these issues and they dont hear it they will charge me for diagnostic time
Old Dec 7, 2015 | 07:26 PM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
Nope, so far ours is creak and rattle free.
Old Dec 7, 2015 | 07:33 PM
Gungaslow's Avatar
2017 C43 sedan
My car ratted like I have a bunch of tools in the back seat sitting on top of fine china.. Anyone fix any of there own rattle?
Old Dec 8, 2015 | 09:06 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
So far, down to about 10F, no rattles or squeaks at all. The brakes screech when cold, but that goes away quickly.
Old Dec 8, 2015 | 01:18 PM
Larry3Jswft's Avatar
C450
You need new friends and a better mouse trap!
Old Dec 8, 2015 | 02:49 PM
xMB007x's Avatar
ML350 BTC & C300
I lubricated the seals of the pano roof and it seems to be helping with the creaking noise.
Old Dec 8, 2015 | 06:07 PM
mvw's Avatar
mvw
2016 C450 AMG; 2015 Infiniti QX60
I got one on the right passenger side. The inside door piece attached to the handle is a bit looser than on the drivers side and sometimes giving it a good shake can get the rattle to go away for a while (though it will probably make it worse in the long run). Could also be a rattle coming from the right side dash, but no idea from what since I don't usually ride with a passenger and hard to drive fast over bumps and such while leaning over into the passenger seat and pushing around on the dash...
Old Dec 8, 2015 | 06:35 PM
Gungaslow's Avatar
2017 C43 sedan
The right side dash rattle for me was the air vent between glove box and passenger door. Had to grab it and twist it a little while pushing in and it finally stopped.
Old Dec 8, 2015 | 09:24 PM
topsider's Avatar
what did you use? ill do that this weekend
Old Dec 9, 2015 | 10:59 AM
mvw's Avatar
mvw
hmmm - that might be it. Will give it a shot.
Old Dec 9, 2015 | 10:56 PM
xMB007x's Avatar
ML350 BTC & C300
I used wd-40 silicone spray. I used a rag to apply it with the roof open at different positions to get all of the seals.
Old Dec 29, 2015 | 03:12 PM
Grant Hummel's Avatar
Current: 2024 GLE350W4, 2016 Audi A8L Previous: 2019 C43W4
Had the EXACT issue on mine. It's currently at the dealer and I just got the call that they've fixed it. My service writer informed me they replaced the pano roof frame. What I noticed is that once the temps cooled, the creak stuck around regardless of the temperature (we've been sitting at 70 degrees here in Charlotte for the past week or so).
I tried WD-40 silicone spray on the seals and it seemed to address the issue slightly, but never good enough. The other interesting thing is that if it rained, it would lubricate the seals enough for the creaking to go away. As soon as it dried out, however, the creaking would start right back up.
They're currently addressing a dash rattle that seams to be coming from the base of the windshield...which has been replaced already because of a good size rock I took to the windshield around 3k miles.
ANYWAY take it in to the dealer and they'll take care of you. Lubing the seal isn't going to ultimately solve the issue.
