8.5x19 will fit on front?
Old Jan 18, 2016 | 07:46 PM
Macks's Avatar
Mercedes C220d 4matic AMG Line
Hi all,
I've a C220d AMG package and stock rims AMG line 18".
Now I want buy a new set for summer, but I've a doubt:
Rims are from Corniche, mod. Conquer, and the supplier told me that
following setup will be ok (without rubbing):
Rims:
Front: 19x8.5 ET45 with 10mm spacer per side
Rear: 19x9.5 ET45 w/o spacers
Tyres:
Front: 225/40-19
Rear: 255/35-19
In my opinion there aren't problem on back, but I'm not convinced about 10mm spacer per side on front.
As he said, these rims needs 10mm spacers in order to avoid issues with brakes.
Do you have experiences on it?
Many thanks!
Old Jan 19, 2016 | 12:06 AM
vic viper's Avatar
S213
8,5" ET45 will work, but not with a 10mm spacer if lowered.
A 10mm spacer will get you 8,5" ET35
Old Jan 19, 2016 | 12:51 AM
Macks's Avatar
Actually lower the car is on my plan..
And ET40 can be ok?
I not sure if spacers are really need to avoid brakes problems...
Old Jan 19, 2016 | 01:10 AM
vic viper's Avatar
S213
Depends on the wheel, my 20x8.5" ET45 Vossen clears the calipers, but my winter wheels 20x8.5" ET45 did not.
Old Jan 19, 2016 | 01:11 AM
vic viper's Avatar
S213
5mm spacer made it work.
Old Jan 19, 2016 | 03:29 AM
Macks's Avatar
My summer wheels are very similar to your Vossen rims (same design), but brand is different.
Your Vossen are very close to calipers but spacers aren't needed, it's right?
I'm thinking to buy anyway 5mm spacers, just to be sure to avoid problems when I'll install new wheels.
Howewer thanks for confirm me that 10mm spacers are too much!
...and my compliments to your car! Very nice setup!
Old Jan 19, 2016 | 10:29 AM
Macks's Avatar
My supplier confirmed me that I'll receive 5mm spacers per side, so I shouldn't have problems , I hope...
I'll post some pictures.
Thanks again!
Old Mar 5, 2016 | 10:10 AM
dmeng's Avatar
2016 C300 Sport 4matic
Just ordered some Vossen CVT 20X8.5 for all four.
Front: 225/35/20
Rear: 255/30/20
I have the US C300 4Matic w/Sports calibers.
Will I need 5mm spacers in the front since its not a 450?
Thanks for your help!
Old Mar 5, 2016 | 05:11 PM
vic viper's Avatar
S213
Front: 225/35/20
Rear: 255/30/20
You wont need spacers, itll be close but work fine
However I wouldnt fit 255.s on a 8.5" rim, might look very bulky, especially compared to the stretched 225.s up front.
Old Mar 9, 2016 | 02:20 PM
OSMS_Carlsson's Avatar
Former Vendor of MBWorld
Mercedes-Benz
Attached are picture of my car when we had the Carlsson package on it, the front wheels are 19x8.5 ET45, and the rear wheels are 19x9.5 ET50.
The car came with the factory 19" AMG multi spoke wheels that are 19x7.5 and 19x8.5. We swapped the tires on to the Carlsson rims which stretched the tire a bit both front and rear, but it looked good and fit properly, and with all the 4 matic cars in the market this set up was applicable to those models as well.
Currently testing is being done for the new C450 as this car has a larger arm on the front suspension. The C63, keep in mind has a wider front fender, so the applications for a 63 version will not be the same application like the standard cars, and the 450 does not have this wider fender either.
If you have a C300 or C400, or a 180 or 250 etc in Europe, the 19x8.5 ET45 and 19x9.5 ET50 will fit and work perfectly with the factory spec 19 inch tires.
The rear wheels with a ET45 will sit past the edge of the fender...so if you run a larger tire it is just going to hang out the fender that much more.
Hope this info helps.
Jim
Attached Thumbnails 8.5x19 will fit on front?-20150505_172434.jpg   8.5x19 will fit on front?-20150505_171714.jpg   8.5x19 will fit on front?-20150505_172249.jpg   8.5x19 will fit on front?-20150426_190923.jpg   8.5x19 will fit on front?-20150426_190807.jpg
Old Mar 9, 2016 | 10:18 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
i;m running 19x8.5 ET45 with a 5mm spacer, as the VFS2 hit the caliper
Old Mar 17, 2016 | 11:33 AM
atl 2 chi's Avatar
Current :2018 E63S and a 2018 GLE 63S . Prior, CLA 250, C450, 2017 AMG C63S
Jim
Jim, any updates on the C450 fitment?
Since the C450 comes with an 18inch front wheel with an offset of +33, would a 15mm or 20mm spacer work with a 19 inch Carlsson 1/10 wheel with an offset of +45 to clear the C450's larger arm?
Old Mar 17, 2016 | 04:18 PM
Mercedes-Benz
The headquarters in Germany has not yet been able to get their hands on a 450 Model to conduct a test fit. As soon as I hear from them I will provide any updates. Sorry for the delay, but I am not able to get them to move any faster, it comes down to them getting the car.
Jim
Old Mar 22, 2016 | 09:00 AM
beceen's Avatar
W205
Jim
thanks for posting this; is the car in pictures lowered or is it a stock suspension?
Old Mar 22, 2016 | 01:47 PM
Mercedes-Benz
My car was not lowered. The width and offset of the wheels pushing out to the edge of the fenders really helped reduce the need to lower the car.
To each his own on doing the lowering...I just don't think the 300 platform is worth lowering...my wife drives the car daily and with the car lowered you need to be more aware of driveways, tire blocks etc. Also the lighter engine of the 300 compared to the 6cyl models makes me concerned about ride quality.
A nice aggressive set of wheels does the trick for making the car look cosmetically better...sure lowering it also really gives it an even better look, but then you start to sacrifice function for daily driving and I honestly did not want to start having to do front bumper paint repairs etc, or hear my wife complain that the $50k Mercedes we bought rides like crap! Just my 02!
Old Mar 24, 2016 | 09:02 AM
beceen's Avatar
W205
so, effectively your ET is 35.
Does it sit well? No rubbing or other problems with drop?
Old Mar 24, 2016 | 09:17 AM
vic viper's Avatar
S213
Nope its 40
Old Mar 24, 2016 | 09:30 AM
beceen's Avatar
W205
eeehh. OK, that was a derp moment.
Sure, it's 40.
Thing is, will ET35 with 19x8,5 up front rub or stick out too much?
Old Mar 25, 2016 | 03:28 AM
Macks's Avatar
Sure, it's 40.
I'll try next thursday my new wheels 8.5x19 ET35 (ET45 + 10mm spacer) on front and 9.5x19 ET45 on back side. I'll share a couple of pictures
Old Mar 25, 2016 | 05:35 AM
vic viper's Avatar
S213
If you ask me ET35 will protrude too much, but then again it is also related to tire size and ride height.
Old Mar 25, 2016 | 05:43 AM
beceen's Avatar
W205
I was thinking 8,5x19 ET35 with factory spec tires 225/40/19 up front and with a mild drop from H&R springs.
Old Mar 25, 2016 | 06:33 AM
vic viper's Avatar
S213
Remember that factor spec front rim is 7.5" wide, a 225 tire will look very stretched on 8.5
Old Mar 25, 2016 | 07:35 AM
beceen's Avatar
W205
this is the setup OSMS_Carlsson uses, and it doesn't look overstretched.
any guesses then, if 225/40 with ET35 and ca. -30mm drop will cause any problems?
Judging by the photo OSMS posted a mild drop should be ok?
Old Mar 25, 2016 | 07:45 AM
vic viper's Avatar
S213
My summer setup use ET44 on 8.5" with 235.s and I rub when the wheels are turned on a uneven surface.
ET35 will rub even more with the same height.
Old Mar 25, 2016 | 07:50 AM
beceen's Avatar
W205
but how low are you?
like one finger gap betwen tire and the fender?
