W205 Steering Wheel Noise
Is this normal for the W205?
Service guys replaced the steering shaft & rubber boot but after 45 minutes of driving the whining noise reappeared again. A C200 owner in Singapore has got this recorded on YouTube so it seems its a universal problem which MB has not yet been able to address.
https://mbworld.org/forums/c450-c43-...deo-below.html
Depending on which of the two sounds you are hearing (and if from outside or inside), it could be the ball joint or just the piece beneath the steering column.
https://www.youtube.com/watch?v=8KJJs8eFmcc
Your video was very clear. I have some good news, I found the video for your particular situation that I came across a few years ago, as stated in my other post if it is happening inside then it won't be the ball joint.
Here is the video youtube.com/watch?v=0y9uUxnqQVM
As suspected, it was the rubber piece that is rubbing.
Here is the solution posted in the video by other youtubers (copied and pasted exact words) (posted by youtuber M.C.):
"DEFINITIVE SOLUTION:
1-remove(partially open) the cover under the steering wheel at the level of the pedals. you will see the column with a bellows and a yellow caoutchouc. the yellow part must be fixed on the column. it wears out over time
2- push the yellow caoutchouc and the bellows towards the bottom of the car frame.
3- surround the steering column with double-sided tape to obtain thickness.
4- pull the bellows and the yellow part each so that it gets stuck/block on the double face that you have installed, and that it turns WITH the steering column. the yellow part can turn inside the bellows with the steering column. no need to change the part.
100% functional solution. no need to put wd40 (not definitive solution)"
If it doesn't work for you, you may check other comments in the youtube video, some suggested WD40 but another youtuber suggested WD40 isn't a good solution.
Best of luck and let me know if it helps.
they also changed the lower control arms and ball joints, i gues they were playing the guessing game so they changed everything
