Squeaking noise when turning wheel, 2017 c43. VIDEO BELOW!
So Recently my c43 starts making a squeaking sound at low speeds when I’m turning the wheel, I’m not sure why this could be in just here hoping somebody could help me. Below is a video of what it sounds like in my garage as I turn the wheel.
so I got extended warranty and Mercedes service told me their not sure if it will cover it so they have to check it out and to do that it’ll be $175CAD and if they end up seeing that the issue is covered I don’t have to pay if it isn’t I have to pay just for them checking it out. I’m just wondering if anyone’s got any advice or if anyone’s had the same issue. Would really appreciate the help!
Edit: Sorry, I forgot to mention the only reason why this part is probably more expensive is because it comes in an assembly, just like you can't just replace one wheel bearing.
The cheapest way is probably greasing it first, good luck : )
Edit: my bad that one is for the facelift, give me a sec
It is a control arm assembly which includes the ball joint.
Check with your mechanic and see if they can install it for you.
To the OP, yep ball joint it sounds like. Try the grease approach first and then replace if it doesn't work. Good luck!
Unfortunately, I haven't find the video but still looking, I will let you know.
I also sprayed wd40 silicon but still had the noise. Yet blasting it with a hose completely sorts it out...
Did you end up finding a permanent fix for yours? Was it a replacement of the A205330840364 Spring Link?
