Post your C450 with Aftermarket Wheels
Old 05-23-2017, 03:55 PM
  #526
Former Vendor of MBWorld
VossenWheels's Avatar
Mercedes Benz E63 S Renntech Stage III
Ill just leave this here
Old 05-23-2017, 04:16 PM
  #527
C43_AMG_NJ's Avatar
2017 C43 AMG
Installed my 20" Signature Wheels
20" Signature rims 20X8.5 235/35/20 Michelin Pilot S4 20x10 275/30/20
Old 05-25-2017, 06:53 AM
  #528
BRBM's Avatar
2016 C450
Whaaaat? Jersey Boy doing some nice work!! Not bad....not bad at all.
SEMA-worthy for sure.
C43_AMG_NJ (05-25-2017)
Old 05-26-2017, 01:39 AM
  #529
tmoneyC450amg's Avatar
2019 E63S
I've tried searching the forums but can't find the answer to my question. Would the 2016 C63S 19" multipoke wheels fit the C450? Do I need any spacers? If so, which ones?
I believe the size for these wheels are as follows:
19x8.5 et38 with 245/35/19
19x9.5 et56 with 265/35/19
If anyone can help me out. Much appreciated. Thanks
Old 05-26-2017, 09:42 AM
  #530
BMWMB71's Avatar
2016 C450 break AMG Sport
In the rear, they will fit perfectly. In the front you will need 8mm spacers.
I would also change front tyres to size 225/40/19.
Old 05-29-2017, 12:34 AM
  #531
Tej7's Avatar
C43 Coupe
Please let me know if you manage to explore this option further. I want these rims on my coupe so bad, but I'm hesitant to experiment with sizes, spacers, etc.
Old 05-30-2017, 10:44 AM
  #532
Hope everyone had a safe Memorial Day Weekend!
Old 05-30-2017, 11:30 AM
  #533
2019 E63S
Thanks for your input and advice. I love the look of these wheels and I like the wider track in the rear. Definitely want to give this a try but just reluctant because I haven't seen anyone do it yet.
Yes, same here. Hesitant myself because I dont have the time to experiment and wary of using spacers. But I definitely want wider tires in the rear with a nice pair of great looking wheels
Old 05-30-2017, 12:39 PM
  #534
alexasa's Avatar
c
there is no reason that the c63 wheels won't fit with the proper spacer and correct tire.
Old 05-30-2017, 07:37 PM
  #535
2019 E63S
Makes sense. But I should use 225s in the front rather than 245s to ensure clearance?
Old 05-31-2017, 12:17 AM
  #536
Tej7's Avatar
C43 Coupe
What size wheels are you running right now? I've got the stock 19" multispokes, and I'm running 225 tires in the front.
Like you, I'm also wary of running spacers. I don't want to risk damage to the car in any way
Old 05-31-2017, 09:18 AM
  #537
alexasa's Avatar
c
I can tell you what I would run if rocking those wheels, specifically, if you are very interested..
lowered or OE ride height?
Old 05-31-2017, 11:42 AM
  #538
Tej7's Avatar
C43 Coupe
OE ride height for me
Old 05-31-2017, 03:39 PM
  #539
2019 E63S
I'm running the OE 18 5spokes now. I just feel these wheels are too heavy. Been wanting to upgrade to 19s and light
  #540
2019 E63S
OE height
Old 05-31-2017, 04:17 PM
  #541
alexasa's Avatar
c
run 5-8mm spacer in the front with a 235/40/19
run a 5-8mm spacer out back with a 265/35/19
you'll need extended lugs. the rears don't need a spacer but the front will be aggressive - so for the front and rear to match - you'll want the spacer in the rear as well.
You can run a wider tire in the rear (up to a 285 - albeit a bit bulbous) but I chose these tire sizes so that the rolling diameter stays the same front to rear and the stretch of the tires on the wheels will be identical. You'll also get 1% taller sidewalls that will help fill the fender gap in and give you a bit more cushion.
I'd probably get a 5 and 8 set of spacers and play around with the look. I am guessing 5 upfront and 8 out back is going to be the best.
Old 06-04-2017, 08:31 AM
  #542
jacobian's Avatar
AMG C43 Coupé
Brabus Monoblock R AMG C43
I bought 8,5 x 19, but the front tire did not fit.
Then I made the rims 1 inch narrower, and now it fits great.
/Stefan
Winter Rims
Old 06-05-2017, 08:58 AM
  #543
Tuono (06-05-2017)
Old 07-19-2017, 11:37 PM
  #544
Gary450's Avatar
C450 amg
Vossen wheels
Originally Posted by Mike@Vossen
All new Vossen VFS-10.....
hi Mike can I get a quote for these in 19s for my c450? Thanks!
Old 08-12-2017, 10:36 PM
  #545
Zed512's Avatar
C450 AMG
Does anybody know what wheel and size is used on the Vath C450 again? I really like the look and interested to price these for my black c450 cheers
Old 08-20-2017, 04:04 AM
  #546
richysh's Avatar
c400
Hello. I currently own a c400 and wanted to get your opinions. Im currently looking fot a set of wheels that are 20x8.5 et45 front and 20x9.5 et45 rear. I know these wont clear the front end of a c450 but this set should be perfect for a c400 right? Would either the rear or front poke at all? And also in regards to the tire sizes, i wanted 245 35 20 in the front and 285 30 20 rear since i didnt really want to compromise the ride quality with 20" wheels. I know the fronts will be fine but what about the rear? Will i have any problem with rubbing anywhere? Ive seen a lot of you guys running 245 35 20 front with 275 30 20 rear but 285 30 20 is basically identical to 245 35 20 and i didnt wanna risk the 4matic system at all, even though the difference between 245 35 20 and 275 30 20 is minimal.
Thank you in advance!
Old 08-26-2017, 02:44 AM
  #547
AMG-010's Avatar
2017 AMG C43
20 x 8.5 - 245 30 20
20 x 10 - 275 30 20
Not sure I like the black wheels may paint silver or get a new set. Lowered on H&R springs, surprisingly rides very well
Old 08-26-2017, 01:29 PM
  #548
Gary450's Avatar
C450 amg
20 x 10 - 275 30 20
let me know if you sell.. I'm shopping around for wheels
Old 08-27-2017, 05:27 AM
  #549
AMG-010's Avatar
2017 AMG C43
I live in Australia so shipping would be very expensive
Old 09-17-2017, 10:05 AM
  #550
Zed512's Avatar
C450 AMG
Been thru this entire thread and still can't make my mind up on aftermarket wheels.
I want to stick with 19s, stock suspension but wider rear track... avoiding spacers if possible. My car is black so something in anthracite might work well. Was looking at TSWs... just need to find a dealer here in Austin.
I bet you someone has the perfect setup and hasn't posted on here yet.
Quick Reply: Post your C450 with Aftermarket Wheels
