Post your C450 with Aftermarket Wheels
Old 07-06-2016, 01:58 AM
  #276
Former Vendor of MBWorld
OSMS_Carlsson's Avatar
Mercedes-Benz
Anyone interested in the Brabus set up, let me know...we are a volume dealer for Brabus and their wheels are a guaranteed fit for your car, so if you are interested in the Mono S 19 inch, feel free to PM me.
Attached Thumbnails Post your C450 with Aftermarket Wheels-brabus-mercedes-benz-c450-amg-sport-11.jpg   Post your C450 with Aftermarket Wheels-brabus-mercedes-benz-c450-amg-sport-2.jpg
Old 07-07-2016, 03:37 PM
  #277
fstclyz's Avatar
C450
I'm looking to buy some OEM 19" split 5 spokes ('16 c450) in black if anyone has a set they want to sell.
Old 07-11-2016, 07:29 PM
  #278
Mercedes-Benz
Originally Posted by aimless
Anyone have info regarding the S205 Estate version of the C450?
Found this article about a company named VATH and they have modified an S205 with 19" wheels with 245 rubber up front. From the looks of the pictures the tires have a bit of stretch so I'm guessing 8.5. Wheels also have some decent concavity to it.
The article mentions aggressive body kit but it looks OEM to me except for the C63 rear diffuser and exhaust tips. Article also mentions upgraded braking but those callipers also look the same.
So does the S205 have a wider front fender than the sedan?
http://www.carscoops.com/2016/04/mer...ment-from.html
This whole thing blows. My reasoning for going with the 18s was so to throw a set of 19" on for summer and use the 18" for winter. If only I had knwon that 8.5s wouldn't fit.. who would have thought.. I'm probably just going to source a set of W204 multi spokes and run some spacers.
I tried to do some checking into this fitment that was posted by Vath, but I think this was a C250 sport that was dressed with the AMG 63 Rear skirt and tips, and a 450 grill...I think they did this article to promote their Engine tuning, but this car never had any photos of the engine or the interior, and the wheel application with a 19x8.5/9.5 with 245/275 tires is absolutely not going to fit a 450 platform with the front suspension. I have emailed the Vath headquarters in Germany to buy this package and or at least confirm the fitment and I received back nothing, so I am pretty sure this is a false example.
Brabus was covered by the same media outlet and their application showed the vehicle fit with the Brabus Monoblock S in 19x7.5/8.5 and it showed the engine and interior etc. so the Brabus application is real.
As far as a 3pc application, I am working with one of the wheel manufactures to test fit a 3pc application...the biggest concern on a 3pc is the Drop Center of the inner barrel may conflict with the Brake Caliper, so once we have a confirmed 8.0/9.0x19 fitment, I will share.
Jim
The following 2 users liked this post by OSMS_Carlsson:
atl 2 chi (07-11-2016), jester4 (07-12-2016)
Old 07-13-2016, 06:24 PM
  #279
chynatown's Avatar
19 C43 Wagon, 16 C450 AMG, 13 C350, 99 ML320 on 20's
Hello,
So I just called H&R directly and they gave me these part numbers;
15mm spacers - 3055665
12x1.5 lug bolts 40mm - 1254001
Can anybody confirm this??
Old 07-13-2016, 06:30 PM
  #280
Mercedes-Benz
Originally Posted by chynatown
Hello,
The new C class W205 uses a 14x1.5mm lug bolt.
With the 15mm spacer we offer and use for the W205 we use a 45mm bolt length. Attached is a picture of a 15mm kit we shipped just last week with black anodized bolts.
Hope this info helps.
Jim
Old 07-13-2016, 08:57 PM
  #281
5Zigen18's Avatar
2016 C450
Hello,
I got the same parts# for the spacers but different lug bolts M14x1.5 42mm
Old 07-13-2016, 09:54 PM
  #282
alexasa's Avatar
c
Hello,
looking at the design - I would imagine these to fit.
The problem I've had with fitment has been the chamfer on the hub-centric extension, these don't appear to have any, which is good.
Old 07-14-2016, 04:36 PM
  #283
nvestr's Avatar
2016 C450 AMG
Is there any consensus on how much closer to the suspension the new wheel can sit vs OEM? Is there any room at all or the OEM standoff is the limit?
Old 07-18-2016, 06:47 PM
  #284
aimless's Avatar
C450
Hello,
I'm using those H&R spacers on the OEM 18".
Front: 15mm 3055665
Rear: 20mm 4055665
No vibrations or anything, but they fit really snug on the wheel side.
Old 07-18-2016, 08:53 PM
  #285
chynatown's Avatar
Front: 15mm 3055665
Rear: 20mm 4055665
Is your car lowered??
Old 07-18-2016, 11:05 PM
  #286
aimless's Avatar
C450
It is, H&R springs.
Old 07-18-2016, 11:17 PM
  #287
chynatown's Avatar
It is, H&R springs.
Do you have any pics??
Old 07-19-2016, 03:31 PM
  #288
fstclyz's Avatar
C450
OK. I'm going to give a bit of insight of why I keep saying things won't fit.
I got the 18" 5 spoke wheels thinking I would use them for winter and throw a set of 19s on for summer. Big mistake as we all know, nothing fits this car. If I had known that, I would have gotten the 19s, which look great anyways and be done with it.
18" wheel/tire specs:
Front: 18x7.5 ET 33 rim, 225/45/18 tire.
Back: 18x8.5 ET 49 rim, 245/40/18 tire.
So, being that I'm stuck, I had a set of 15mm H&R spacers that fit this car. I threw them on the back, perfect, the wheel was now flush.
So with the 15mm spacers in the rear, it gives me a final ET (offset) of 34.
I decided to throw it on the front and see what happens, knowing it would poke. Well it poked out about 5mm, so back on the rear they went.
I then had the car lowered on H&R springs.
The 15mm that worked on the rear before was now 5mm from being flush with the fender. So I put the 15mm on the front and bam, it was flush with the fender giving me a final ET of 18 in the front. So I ordered 20mm spacers for the rear, giving me a final ET of 29.
Before I lowered my car, I stuck my fingers in her and felt around. I could only fit one finger between the wheel and the suspension. Let's say that is about 5mm. I wish I could get both fingers maybe even 3 fingers in her, but she's TIIIGHT.
So anyways, plug this information into this website: Willtheyfit.com
Front: 225/45/18 18x7.5 ET18
Rear: 245/40/18 18x8.5 ET29
That will give you flush with fender without poking for front and rear with the OEM tires, on a lowered car. Figure it will poke about 5mm for non lowered cars.
Now plug in whatever wheel you want, and see how it fits. We can also roughly assume that we have an inner clearance of less than 20mm from where my wheel sits. Reason being, I had about 5mm before the spacer, so adding the 15mm spacer should give us roughly 20mm and NO MORE.
So for sh*ts and giggles lets plug in fstclyz desired wheels into that website.
225/35/20 20X9 ET38.
It says right off the bat that its going to be 39.1mm closer to the suspension strut. Well through my unscientific research, thats about 19mm too much. Even if I'm wrong, I don't think I could be off by more than a few mm. Hell lets say I'm off by 10mm. Still, won't fit. Unless you don't mind the wheel poking out.
Also keep in mind on a stock height car, that's already poking by about 5mm.
Disclaimer: I'm not responsible if it doesn't fit. The stock tires are pretty round, so something like a Michelin PSS might end up being too wide.
Edit: Didn't bother with the rear since we don't have any issues with that.
This is really helpful so long as it's accurate and it sounds like you did your homework. I'm looking at aftermarket 19x8 for the front and deduct from your finding that a 19x8 just barely fits and the correct offset would be a
24et. That still takes up 10mm on the inside, giving me maybe 10mm of clearance (inset). It seems like I could go up to a 27et with a 5mm clearance but man, this is getting really tight and not many people make 24-27 offsets anyway.
It would be nice to get this info using a 20" as there's talk that we gain some inset by missing the suspension.
Old 07-19-2016, 04:31 PM
  #289
aimless's Avatar
C450
Well nycsoil has 19x8.5 et 31 with 225/40/19 tires.
Using that website, the face of his wheel sits nearly identical to mine with spacers. And his inner wheel is 25.7mm closer. So seems like my 20mm guess is conservative and we have a new number of 25.7mm
Old 07-19-2016, 05:49 PM
  #290
fstclyz's Avatar
C450
That opens up more options for sure. Your finger test was maybe just a bit off..... So maybe we have 30mm to work with back there (inset) using a 77mm poke to keep the wheel/tire flush on a lowered stance.
Old 07-19-2016, 07:28 PM
  #291
chynatown's Avatar
Front: 15mm 3055665
Rear: 20mm 4055665
What size lug bolts did you order with this set up??
Old 07-19-2016, 08:19 PM
  #292
aimless's Avatar
C450
14x1.5 45mm. More than 8 turns. I stopped counting. Doesn't hit anything.
Old 07-21-2016, 03:53 PM
  #293
nvestr's Avatar
2016 C450 AMG
I ordered my C450 with the 19's but want to swap them for 18" tire/rim combo for winter. I do want a wheel that has a Mercedes look to it. Currently looking at the Replika R170 (https://www.replika.ca/productinfo.a...mercedes&bp=-1)
It is 8.5 wide wheel with +32 offset. As it stands, it would be :
Compared to your existing wheel, this new wheel will have an inner rim which is 11.7mm closer to the suspension strut. The outer rim will poke out 13.7mm more than before.
11.7mm closer is most likely cutting it too close, right?
So, if I get a 10mm spacer, it would land me at this:
Compared to your existing wheel, this new wheel will have an inner rim which is 1.7mm closer to the suspension strut. The outer rim will poke out 23.7mm more than before.
Do you guys think that it would be acceptable up front? 10mm spacer with 8.5 inch wheel? 23.7mm is 0.93 on an inch... Is that too much?
Alternatively, would a 5mm spacer work, thus bringing me 6.7mm closer to suspension than stock??
Old 07-21-2016, 03:55 PM
  #294
Albanmtexas's Avatar
C450amg 2016
I have stock 18s on run flats 400 miles on them. Would be willing to part ways go to my Instagram page amg_of_texas and dm me and you can see the wheels
Old 07-25-2016, 10:49 AM
  #295
nvestr's Avatar
2016 C450 AMG
Thanks but I can only imagine the cost of shipping them to Canada... SEems like a huge hassle and probably not worth it...
Old 07-26-2016, 02:01 PM
  #296
jester4's Avatar
C450
I can't wait to start looking for 18" winter rims and tires in a few weeks. That should be fun
Old 07-29-2016, 02:58 AM
  #297
nadeau's Avatar
2016 C450
Jim
Do you have a link to these spacer kit? i would like a set for my C450 please
Old 07-29-2016, 01:28 PM
  #298
Mercedes-Benz
Feel free to email me directly and I will gladly send you a kit and honor the price I did for the group buy.
Jim
Old 07-30-2016, 08:48 PM
  #299
nadeau's Avatar
2016 C450
Jim
Sent you a email
Old 07-30-2016, 09:28 PM
  #300
chynatown's Avatar
Sorry for the terrible pics, new ones to follow as soon as I get my rims back from refinishing!!!
Attached Thumbnails Post your C450 with Aftermarket Wheels-mb.jpg   Post your C450 with Aftermarket Wheels-mb1.jpg
Quick Reply: Post your C450 with Aftermarket Wheels
