NPP (Night Package Problems)
Any ideas? Pics below.
My last c class had the same issue on the lowers.. it was a clearcoat layer delaminating.. polishing it will do bugger all IF its the same issue as its the delamination changing the appearance, not the top surface.
I have 2 sets of window trims on warranty through the life of that car..
It was exaggerated by the very harsh sun we have here.
And the last car was very infrequently waxed / protected (regularly washed though)
Suggest replace on warranty, then get into the habbit of using a durable wax / sealant product after washing..
Collinite 845 insulator wax is great product, low cost high performacne and durable, every 3 months or so would typically be more than enough.. there are of course a ton of others to choose from..
look on Autgeek online forum re using the collinite for best results and knacks etc..
All the best...
If I can find the page number I'll edit and post the citation for this^^^.
I plan on taking my MB to touch less car washes. Is there a guide of best practices with maintaining the exterior? (How often to wash, how often to wax, etc)
My cars can be driven in a rainstorm and when they dry they dry clean. Usually I'll devote a weekend to getting four or five coats on, and I won't touch it again for a year. In the meantime i run it thru touch less or soft touch washes. The Zaino seems to protect from scratches.
Visit www.zainostore.com
Here's the first order I'd place. The cure accelerator you'd only use for the initial application session. It allows you to layer multiple applications without waiting 24hrs between coats.
