Wheel 18" or 19"
Old Jun 5, 2016 | 12:48 PM
adrian777's Avatar
Mercedes w205
Wheel 18" or 19"
I'm 17 " and I 'm thinking about 18 or 19"
consumption is much difference with 18 ?
and consumption with 19 "?
Old Jun 5, 2016 | 01:12 PM
Mike5215's Avatar
2016 C300
No difference. The overall wheel diameter (tire+rim) stays the same. You're just swapping rim diameter for sidewall height.
Old Jun 5, 2016 | 07:00 PM
Mr. J's Avatar
C450, GLC43
19s will ride a little harsher than 18s and quite a bit harsher than 17s. Keep that in mind if a soft ride is important to you.
Old Jun 5, 2016 | 07:17 PM
alexasa's Avatar
c
Saving weight on wheels can aid in consumption, theoretically.
Old Jun 5, 2016 | 07:36 PM
inhartwetrust's Avatar
19" all day every day.
Old Jun 5, 2016 | 08:13 PM
Mike5215's Avatar
2016 C300
That's true, although I have to say honestly that in all of my wheel decisions, fuel economy is never on the table. I guess rather than rim diameter, look for tires with low rolling resistance like the Michelin Primacy or whatever they put on the Prius or Leaf.
Old Jun 5, 2016 | 08:34 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
+1 as long as you run non-runflats
Old Jun 5, 2016 | 08:53 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
I believe not correct, the 19's are wider and have a higher rolling resistance, (albeit slight.. ) there is a small loss in fuel efficiency.. (0.2 - 0.3l / 100kms)...
all other commetns re ride feel are absolutely valid though...
Old Jun 5, 2016 | 09:24 PM
Mikey53's Avatar
Veteran: Air Force
In other words, carrying a passenger or driving into a head wind has a bigger impact.
Old Jun 5, 2016 | 09:27 PM
Shadwell's Avatar
In the US yes.. cos the passengers likely weigh 200kgs
Old Jun 5, 2016 | 10:20 PM
Mike5215's Avatar
2016 C300
Nonsense. I learned everything I know about the British from watching Benny Hill and there are a lot of fat people in England. Especially the ladies, many of whom also look a lot like Benny Hill.
Old Jun 5, 2016 | 10:29 PM
Will burn through the tires that come with it first, then I immediately switch to non run flats Michelin PSS. For my winter tires I'll also be going with non run flats, not certain exactly which tires though - maybe Blizzaks?
Shadwell's Avatar
They exported Benny to the US.. very popular over there too.. hmmm
You are corrcet, it is an accurate portrayal of the Pomms.. (English).. The Welsh and the Scots are Legends...
