Buzzing from front middle speaker, rattling in cabin W205
I just purchased a C450 AMG and am already having issues with buzzing of the front middle speaker. It seems too only play around 300 hz frequency which is really irritating when I play sat radio or talk shows.
Also, there seems to be alot of rattling when I go over road bumps or uneven surfaces coming from the sunglass areas.
I've taken it to the dealer and was told these are just normal parts of the build. Is it worth having these pieces taken apart? I dont want them to get worse!
Is anyone else having these issues and how can I fix it? Quite irritating for a new car!
You can also pack any interior seams that are creaking against each other with it. Usual suspects are top of dash between the upper dash pad and the plastic gauge binnacle, behind the screen where it mounts to the dash, and along the underside of the metal "spear" that runs across the dash.
http://www.parts-express.com/parts-e...-roll--260-540
The dealer's technicians are supposed to take the car for a test drive and diagnose the problem, as was done in my case. They even offered me to take a ride with them to show them the problem (I declined). The rattles I had are gone.
BTW, I got my car on Sept-1. So I'm on the same boat..
As for the speakers on my former '14 C, I had buzzing too, dealer simply replaced the speaker and sent me along my merry way. (warrantied)
The creaking and groaning in the car is not standardised and therefore not there by design intent.
It is due to a mix of poor / variable construction, and a lack of proofing from the manufacturer.. ie a warrantable correction is correct.
This car has many sources of interior noise due to panel / part flex and movement. Fixes include correct assembly, lubrication, and separation.. (ie barrier material).... in some case all of the above..
I have personally removed all door card, rear hatch panels, b pillar panles, dash binncale and the center console and rebuilt all adding sound deadner, barrier materials, lubricating, and correcting assembly errors (incorrect cable routing and adding fixing points to prevent vibrations, fitted missing assembly screws in tthe cnetre console assembly...
Granted have an automotive manufacturing engineering and product design and devel background.. but all that did is save me tolerating the dealership model to seek correction.. ie now i know its done right.. there is no way they can adequately attend the qty and level of correction required within the constrainst of warranty placed upon them..
All the ebst with getting your corrected..
Smack gently..... ensuring the tabs are aligned correctly before hand..
(trying to avoid a trashed part.. )
Is it worth doing this felt taping by myself or should I keep sticking it to the dealer?
Any ideas how to fix this? its driving me crazy!
1) How do you remove the silver gauge cluster surrounds to add vibration felt/tape
2) How can you remove the stainless trim piece that goes across the center of the dash (for the same reasons)?
3) Is there anywhere else typical of rattles that someone can explain remove of parts?
I have a complete trim puller kit, and I'm not a pansy at all (used to pull apart my Audi S4 all the time), but the Merk is a different animal....
