Auto start stop.. stopped...
Old Oct 10, 2016 | 01:02 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
So I know many hate the stop start but as I do very short trips I value the feature.
for the last 18 months it's kicked in really soon after start up.
until last week when all I get is the amber circle. It's not worked at all not even after several longer journeys.
annoyed.
Old Oct 10, 2016 | 01:06 PM
chrisdean's Avatar
W205 C200 AMG Line Premium
Mine didn't start working regulary until June so I suspect that the outside temperature is quite a major factor in its operation.
Old Oct 10, 2016 | 01:18 PM
ManiacGT's Avatar
Its always worked, in every season. Not a single trip in the last week or two has it gone green/kicked in.
Old Oct 10, 2016 | 02:06 PM
MASSC450's Avatar
2026 GLE 53 Coupe
Count your blessings...
Let us know what happens at your dealership after you take your car in.
Old Oct 10, 2016 | 02:13 PM
ManiacGT's Avatar
Im loathe to do that as A) that's a pita. And B) other threads I've read say most dealers just quote it's due to changing parameters.
Old Oct 10, 2016 | 02:45 PM
LateC300's Avatar
2015 C300
mine was shutting off completely and no green light would come on. but the problem was due to having an engine malfunction (faulty spark plug causing misfire) so the start stop function was acting up due to that.
cant hurt to take it in and get everything checked over
Old Oct 10, 2016 | 03:21 PM
chrisdean's Avatar
I had an "Auxiliary Battery Malfunction" for a few weeks which was replaced under warranty, whether that was related or not I don't know.
Old Oct 11, 2016 | 02:22 AM
ManiacGT's Avatar
Thanks for the replies. The manual states that the yellow icon means available and no faults but that the conditions to activate aren't yet met. Manual states that if there's a malfunction it wouldn't even show the yellow icon.
Old Oct 11, 2016 | 10:52 AM
LateC300's Avatar
2015 C300
makes sense, as the malfunction in my car didnt produce a yellow light...ive never even seen that light before. maybe it's a Euro-spec thing?
Old Oct 13, 2016 | 12:38 PM
ManiacGT's Avatar
So still no joy booked into dealers at earliest opportunity with a loan car.. 9 Nov!
Old Oct 14, 2016 | 12:10 AM
Xtrema's Avatar
2020 GLC43
I used to hate my auto stop but now I love it. It saves me around 10% in gas compared to similar car I had before without one.
I too have wonder what condition it has to reach for it to disengage. So far it has done it to me once or twice and both are early in the drive. I wonder battery voltage is one of the metrics and if your car has some unknown parasitic draws on the battery.
Old Oct 14, 2016 | 03:10 AM
ManiacGT's Avatar
Thanks for the response. i did think about that and disconnected anything on such as USB devices etc and have run the car for some weeks now, still nothing. Other than outside temps going from 20c to around 12c now nothing has changed and it's never stopped working before even in near freezing conditions.
Old Oct 17, 2016 | 08:23 PM
Trancebolt's Avatar
w212 E350 Bluetec & Mk7 GTI Sport
I almost notice that it decides not to activate more often on days where I manually disable it or switch modes more often. Like it resets the logic that enables the start/stop. Some form of amount of time waited at idle x % of below average fuel consumption being read. Algorithym getting thrown off.
Clearly I cant spell algorithym so don't take my word for it, just a hunch.
Old Oct 18, 2016 | 02:09 AM
ManiacGT's Avatar
I never disable it, fuel consumption on the 4 cyl turbo is bad enough to make me use auto start stop.
Old Nov 4, 2016 | 02:23 PM
ManiacGT's Avatar
Lamp went green again today. Nearly two months since it stopped working. Odd
Old Nov 4, 2016 | 03:20 PM
chrisdean's Avatar
I've noticed recently that although my green light eventually appears, if I switch the A/C off, the green light comes on.
Old Nov 4, 2016 | 03:44 PM
ManiacGT's Avatar
thats normal, start stop won't engage until interior temp and humidity is reached
Old Apr 10, 2022 | 05:26 AM
ausbenz007's Avatar
gla
did you solve the problem?? we got same issue
Old Apr 10, 2022 | 09:28 AM
mikec35's Avatar
2016 C300 sedan
Mine stopped working as a first sign of the main battery aging. Replaced the main battery and after a few drives the auto stop/start was working as normal. How old is your battery?
Old Apr 10, 2022 | 04:02 PM
Ron P Baker's Avatar
2016 C300 Luxury
In my case I had to replace the main battery and the "auxiliary battery" (capacitor/voltage regulator). "Auxiliary battery" was defective and main battery was at the end of service life.
Old Apr 11, 2022 | 11:05 AM
Gazwould's Avatar
S204 C250 CDI Sport
So called fuel saving device that costs more in replacing components early .
Also on the list is starter motor , alternator , engine mounts and drive chain tensioner.
Old Apr 11, 2022 | 12:34 PM
dwpc's Avatar
2017 C300 Cab 4Matic
It stopped working in my Cab a few weeks ago; not that I miss it. The green indicator is still on.
Old Jun 26, 2022 | 06:39 PM
mostafa.ezzat's Avatar
e350
I changed the auxiliary battery now with original Mercedes Benz battery and it’s still not working I think it might be the main battery but I will wait until it’s completely dead to change it
