Hardwire Radar Detector
Old Nov 6, 2016 | 07:16 PM
porshah's Avatar
C300 4Matic, BMW Z4, BMW 428i xDrive, Lamborghini Gallardo
Hello All,
I am new to this forum.
I searched through the forums on hard wiring a radar detector (first thing I usually do to any new car I get). Didn't really find any good details or step by step instructions, so I figured I would contribute.
I am sure this is applicable to other series MB cars, but these instructions are for 2016 C Class (W205). I used the fuse box by the drivers side front.
What you will need: Some basic tools (see Image 1 below)
Difficulty level: 3 (on a scale of 1 to 10)
Time: Approximately 20 minutes
Radar Detector of your choice (I am using Escort 9500iX).
Image 1
Hardwire Radar Detector-8061e1ac-d17b-45b9-8990-aaf5619b1723_zpsfmkkmrll.jpg
Start by opening the drivers side fuse box using a plastic pry tool. Start in the middle and slowly work your way around.
Image 2
Hardwire Radar Detector-3b9c6d3f-063c-4014-b79c-4afcb46d02bf_zpsy73v6yr9.jpg
You will see the fuses as shown below.
Image 3
Hardwire Radar Detector-d5a06261-6477-4fd9-8547-c3ccdb56d016_zpszlsdprxb.jpg
I used the direct wire Smart cord purchased directly from Escort
Image 4
Hardwire Radar Detector-aa576359-520b-4fda-91c7-fcfe76aeceb0_zpsfqpfccs2.jpg
Pass the wires of this cord through the opening behind steering wheel. I like having the warning indicators and mute button within easy reach.
Image 5
Hardwire Radar Detector-ba3a3f94-59d0-4d99-a3d4-def1e54a1cb0_zpsxld96fie.jpg
The trim piece easily pulls out
Image 6
Hardwire Radar Detector-4b00a632-85c8-4ca4-8783-8dd52f4081cd_zps1g9t3pyl.jpg
Image 7
Hardwire Radar Detector-ad9a2910-a271-4fe4-b2dc-e5e5acdb7b1a_zpsk7wy2iyf.jpg
Use a wire puller or hanger
Image 8
Hardwire Radar Detector-1818ec28-8807-4b9a-b329-8b8bacebd7b9_zpsomzd2is1.jpg
Tie wires to the end of wire puller or hanger
Image 9
Hardwire Radar Detector-dad6bac9-2029-4734-905b-127809b6f48e_zpsv4aluths.jpg
If you remove the bottom trim piece under the steering this will make pulling the wires a bit easier.
Image 10
Hardwire Radar Detector-20f7db8f-50b2-4e2a-aa23-025379549e70_zpsmacjfawd.jpg
You will need T20 Torx screw remove the trim pieces
Image 11
Hardwire Radar Detector-f36bc415-6c40-4bd1-9c9e-ee42db3955f9_zpst41k3rc1.jpg
I used Fuse 216 – this will turn the detector on and off when you turn the car on and off(see image below)
Image 12
Hardwire Radar Detector-489b8572-b45f-4a3f-9ba1-b20bdc9dc196_zpss2w4z1nc.jpg
Pull the fuse out using either a Fuse puller or set of needle nose pliers.
Image 13
Hardwire Radar Detector-94dcd7fb-3f85-4366-a35f-ae17de59b0d5_zpsu6kktutr.jpg
Strip the end of the wire and wrap it around the fuse as shown.
Image 14
Hardwire Radar Detector-6f1bc507-b930-4bfc-a311-412767252414_zpsjjksbsvu.jpg
Reinsert the fuse as shown below
Image 15
Click image for larger version
To the left of the fuse box (where the door hinges), you will see a bolt. This is a perfect place to use for ground. You will need 13mm socket to loosen the bolt. Slide the ground wire behind the nut as shown and re-tighten the bolt.
Image 16
Hardwire Radar Detector-000b6f29-dd1d-4552-946a-2e0b78172972_zpsbjj3yg9h.jpg
Image 17
Hardwire Radar Detector-61e7a039-28ee-4ce1-9cc9-3d234f87227d_zpsmwb7qplm.jpg
That takes care of the hard part.
Now you need to run the wire for the radar detector. I mounted mine just to the left of the rear view mirror, behind driver’s side sun visor.
Image 18
Hardwire Radar Detector-ff9ac66f-e6a3-4589-ae38-7f68a4e71ebf_zpsbjuqdoxr.jpg
I was able to run the wire along the trip on the left edge and up the A-pillar.
Image 19
Hardwire Radar Detector-1d2aa853-d0da-4bc4-8af8-c1c44432687a_zpswnnb06lf.jpg
Image 20
Hardwire Radar Detector-ea76fa3e-9ae2-46d5-88c8-f27edab552d6_zpsr4wnf8fa.jpg
Use the plastic edge trim piece to slide the wire under the trim so it is not visible.
Image 21
Hardwire Radar Detector-6476fd00-e773-48d2-8d9f-1b5511becf75_zpsowotdqbl.jpg
Bundle up excess wires and hide under the trim piece.
Image 22
Hardwire Radar Detector-7acf6741-a9f8-412c-9980-598cc6d04b3d_zpsstclckgt.jpg
Replace all the trim. You are all set.
Hope this is helpfull. If you have any questions or need additonal information, let me know.
Old Nov 6, 2016 | 08:24 PM
Mike5215's Avatar
2016 C300
Nice! You can also tap 12v switched power from the rear view mirror housing if you don't need to wire in a Smart Cord and want a shorter cable run.
Old Nov 6, 2016 | 09:34 PM
auditoamg's Avatar
C63s
Mike, where did you pull power from for this method?. I haven't seen this attempted? I used the Homelink in prior cars... Can you give us a quick write-up on this, as I definitely want a shorter run....
Old Nov 6, 2016 | 09:58 PM
Mike5215's Avatar
2016 C300
Well sadly I had the shop who installed the audio gear do it while they had the car.
Old Nov 6, 2016 | 10:10 PM
auditoamg's Avatar
C63s
Crap!!! LOL
But it is only wired to the overhead console?
Old Nov 7, 2016 | 11:59 AM
porshah's Avatar
Short cord is a nice option. I prefer to have the mute button within easy reach.
Old Nov 7, 2016 | 12:21 PM
CO2010's Avatar
2015 C300 RWD Sport Premium
Great write up! This should also work for my V1.
Old Jan 9, 2017 | 10:12 AM
jherm's Avatar
C63S
I just got a Passport Max 2 after being out of the radar detector market for 7-8 years. What is the point of the SmartCord in a setup like this where the actual detector is easily within reach being mounted to the left of the rear view mirror? It looks like the info the SmartCord provides and the ability to mute on it just duplicate info and ability to mute that you already have on the detector. I would get if the detector was mounted in a location that wasn't easy to reach and mute so the SmartCord mounted closer would be helpful. But in this situation, what's the point of the SmartCord?
Old Jan 9, 2017 | 12:10 PM
porshah's Avatar
For me it was two reasons.
1-I already owned the cable with SmartCord. When I sold my previous car I simply removed it and reused it. In my previous car I had the detector on the passenger side of rearview mirror, because I couldn't completely close the sun visor on drivers side where the detector was mounted. In that case it was nice to have the mute button within easy reach.
2-I like having the lights in my line of sight. Most detectors have "Auto Mute" feature, and sometimes you forget there's an active threat.
If you were buying a new cord, it's your preference. It would be much faster and easier to have just one cord to run to the detector.
BTW, Max 2 is nice. I recently upgraded the 9500ix to Max 360. They had a Black Friday sale when it was 30% off the original price.
Old Jan 9, 2017 | 10:06 PM
B2FiNiTY's Avatar
'16 GLC300
Thanks for the awesome writeup.
I'll use this guide to wire up my dash cam.
Old Apr 16, 2017 | 07:32 PM
SoDakBenz's Avatar
2015 C300 Sport 4Matic, 2014 C300 Sport 4Matic
Great walkthru. I just hard wired my escort 9500xi. Been wanting to do this for awhile.
Also took the time to install a dashcam. The power cord that came with was the perfect length to run in the headliner next to the windshield and down the A piller and down to the bottom of the dash and back to where the carpet meets the dash on passenger side and then tucked the wire under the center console and back to the 12 volt on the back of the armrest. The cord literally had 5 inches extra length like it was made for our car. The dashcam I got was DOD460w.
Old Apr 17, 2017 | 09:21 PM
porshah's Avatar
Nice! Glad to help.
Old Apr 23, 2017 | 04:06 PM
flycaster's Avatar
2017 C300 Coupe, 2013 Cadillac ATS 2.0T
Good job with good pictorial instructions. I did my V1's fuse hookup the same way; and, as you did, I ran the wiring up the A column to the headliner, but placed the V1 into its visor clip placing it on the right side of the driver's visor. This way the V1 was not showing as much as it would if I had used the suction cups. Just saying...
Old Apr 23, 2017 | 04:46 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Curious why you wrapped the wire around the fuse blade instead of using a fuse doubler. Clearance? Also noticed that your fuses do not have the little "s" next to the amp rating. Some OEM fuses have that designation and they are impossible to find.
Amazon Amazon
Old Apr 24, 2017 | 09:59 AM
porshah's Avatar
No need to buy fuse doubler, it works just fine wrapping it aroud.
Old Apr 25, 2017 | 10:03 AM
auditoamg's Avatar
C63s
Imho, fire waiting to happen without a proper fuse doubler.
Old Apr 28, 2017 | 09:39 AM
porshah's Avatar
Have been doing it this way on all my cars for the last 20 years. Have owned 39 cars to date. If you feel safer with fuse doubler, then by all means...
Old Apr 28, 2017 | 06:30 PM
auditoamg's Avatar
C63s
I just paid my dealer to re-wire.
It was well worth it.
They actually wired my cam, detector and 2 other accessories into the spare slots i the fuse box by ordering additional fuse receptacles, etc.
I've also learned there's a junction in the car called Bus25 (I believe) that will provide voltage until the battery gets to 11.5 volts (perfect for dashcams in parking mode) where the relay shuts it down automatically.
It can be reached behind the fusebox, but we chose an alternative route....
Old Apr 16, 2021 | 09:09 AM
anerbe's Avatar
C63S past: E90 M3 6M, w211 E55
Switched Fuse in Driver Door Panel
Hi guys,
sorry for the old thread bump up. Just wanted to clarify the switched power fuse in the driver side fuse block.
post found here: https://mbworld.org/forums/c63-c63s-amg/748466-hardwiring-radar-detector.html#post8203725
its fuse 218 - the 7.5 amp on the right, that is switched.
The instrument cluster 7.5 fuse on the left side in this thread stays on after the car is switched off, as you can bring up the screen by pressing the left side home button on the wheel to light up the screen with ignition off.
had to do some trial and error, and was about to reroute the pillar wiring to the passenger side if I didn’t find the fuse post.
Old May 3, 2022 | 02:34 PM
Kush Desai's Avatar
2016 C300 4Matic
Sorry to bring up an old thread but I believe the OP used Fuse 216 (5 Amp Fuse). Not Fuse 208 (7.5 Amp Fuse). I think OP only pulled Fuse 208 for picture purposes to show how to pull the fuse.
OP states "Fuse 216 – this will turn the detector on and off when you turn the car on and off".
Personally, I think you could use both Fuse 216 OR Fuse 218, as long as both are "switched" Fuses. Meaning once the car turns off, the Radar wired to that fuse will also turn off. Same when you turn the car on, radar should turn on.
Old Jul 15, 2022 | 01:26 AM
nardoC63s's Avatar
2016 C63s
So if I used fuse 208, would that kill the battery in my car? I use an escort max 360c and the screen shuts off but I’m not sure if the car is supplying power at all times to the gauge cluster
