FINALLY!!! Performance Air Intake
Re: believing in Santa, maybe so does the MB marketing team, based on last year's holiday ad ?
But seriously, while I totally acknowledge and respect the experience of other thread posters who have been under MB hoods/bonnets for decades, and the comments you have posted, isn't K&N making a decent case that incidents of oil build-up on the MAF sensor aren't related to the treatment on their filters: http://www.knfilters.com/news/news.aspx?id=422 ?
Out of the box, at least. The oil individual consumers add to the filter after washing it may be a different matter: what if you get a few folks who add more than the recommended amount of oil, thinking more is always better? or if the consumer-added oil treatment isn't given sufficient time to dry before re-installation? Could these explain the handful of sensor problems?
The responsibility of over oiling is clearly with those other than OEM.
People do things without due consideration.
Point is an oiled filter is unnecessary.
Additionally, removing the intake all together will produce no discernible difference in engine response, ie the rate at which the rpm rise relative to time and accelerator pedal position. So expecting a filter medium to effect a discernible difference is incorrect.
HOWEVER, perception and belief are powerful factors.. so those that hear a little more or different noise will interpret this as a change in xyz... it is only a change in sound however..
Point is get them if you aren't after optimal filtration and want a small change in noise (panel change), a cone or pod with removal of intake system may provide more noise (and often case decrease performance measurably due to the loss of CIA...). That's all fine but at least admit its for the noise / or cos you felt like it... they are perfectly good reasons to do something on your own vehicle....
chicago-guy (01-03-2017)
#32
I not doubting what you say here, but where are you getting this information from that the intake/stock air filter on a W205 is not a "constraint"?
I ask because after switching out the stock panel filters on my old 2015 C300, and my current C450, I most definitely felt improved engine response.
Hence the power gains need to be sourced from either greater power production or loss removal....
What at you experienced was potentially increased noise at a given rpm which you interpret as increased "response". In fact the rate of rpm increase (or response) remains unchanged.
But increased intake noise can be fun so it's cool you got the items and that you enjoy them.
#34
Now when it comes to just a cone filter and intake tube that replaces the stock air box...what I call a hot air intake because air is drawn in from the hot engine compartment (heat shields do nothing), well I don't believe in those and never have. Those are definitely just noise makers.
#36
#40
Throttle response will not be affected in any measureable way by the changing of the filter element..
Take the filter out all together and you still won't get a change... i.e. an increase in rate of rpm gain with pedal depression over a time base...
IF you want that a pedal commander or adjusted factory software will certainly make a noticeable difference as the signal from the pedal is amplified (non linearly).
I am about done on this topic though.
All the best.
All the best.
#41
Yeah, go figure, and not only that I have also in spite of my lack of motor knowledge and skills built and tuned two race cars with standalone ECU systems, those experiences have by far exceeded my accumulated knowledge from my 16 years at Daimler.
Hence my interest in fake *** "tuning" products being scammed onto the average joe.
#42
But pairing it with those other bits should make for a nice little ride with all kinds of decent noises... I'm curious though, what kind of power are people pushing out of the stock turbo on the c300's?
And on a serious suggestion based on my experience of modding 4 bangers to 400+hp: Make sure whatever intake you run has a proper heatshield. Or route it in a way that it gets a substantial flow of fresh, cool air. You do NOT want an intake that is pulling in stagnant engine bay air. In other words: No one has ever had success increasing power with a 'Hot air intake'
janusgrimnitz (01-05-2017)
janusgrimnitz (01-08-2017)
#47
#49
https://mbworld.org/forums/c-class-w...00-glc300.html
There is a thread with my review already. You can hear it there.
