Where's the wash liquid reservoir?
Old 03-02-2017, 04:49 AM
mun
mun's Avatar
n/a
Hi
I'm having issues with the windscreen washer. When the button is pressed, no fluid gets pumped out but the wiper still activates. I want to check the reservoir level, but where's the reservoir? I can find the opening, but much of the parts seem to be covered up.
Any help appreciated.
Old 03-02-2017, 05:47 AM
vic viper's Avatar
S213
Have you pressed the button firmly all the way inwe have had several customers with the same issue not pressing the button hard enough.
Old 03-02-2017, 05:58 AM
mun
mun's Avatar
n/a
I believe I did. The wiper activated though - just not the washer. I doubt the reservoir is already dried up since I've only used three times since I got the car.
Old 03-02-2017, 07:25 AM
Razzyh's Avatar
W205
press the button a little activates the wiper, press it harder it activates washer and wiper.
If wipers were low on fluid you would get a message on the dash.
Old 03-02-2017, 09:08 AM
Mikey53's Avatar
2016 C300 4Matic traded in for a 2022 E450 Coupe
Hi
Push harder to get to the second detent
Old 03-02-2017, 09:28 AM
mo11's Avatar
2017 C43
https://www.mbusa.com/mercedes/owners/videos/detail/year-2017/class-C_Sedan/videoId-d82dd68b2c51d310VgnVCM2000007d184335RCRD
Old 03-02-2017, 10:03 AM
mun
mun's Avatar
n/a
Oh! I didn't know there were two detents. That did it indeed! Thanks.
Old 03-02-2017, 12:46 PM
DapperStyle's Avatar
2014 C300
Old 03-02-2017, 12:49 PM
Jawknee_5's Avatar
C400
This happen to me also when I first got my car. I ended up down at the dealership and one of the Tech showed me that I had to push harder. That was embarrassing.
Old 03-02-2017, 01:29 PM
Razzyh's Avatar
W205
Perhaps people should read the manual or if your really lazy MB have done some videos
Old 03-02-2017, 06:52 PM
dbldpr's Avatar
Woman I know brought car into gas station and had attendant fill the washer canister. Later she went to use it and nothing came out. She brought to dealer. He said there is nothing in it. Found out the gas station guy filled the hydraulics canister with washer fluid. Looked like a slurpee in canister. Cost her about $8,000 to flush out and replace almost everything that used the hydraulics. Be careful what you fill up.
Old 03-02-2017, 07:30 PM
BenzC400's Avatar
E53
I had the same issue shortly after taking delivery. It turned out the washer pump had failed and needed to be replaced.
Old 03-02-2017, 10:16 PM
PR2000's Avatar
2017 C43 AMG Sedan
Took me a few minutes to figure it out also. I was too embarrassed to go to the dealer so opened up the hood like 5 times in the pooring rain to troubleshoot it then read the manual....
