Speaker Distortion 2015 C400
Old Mar 15, 2017 | 12:59 PM
c400ry's Avatar
2020 AMG GTC
I thought I would update the forum on a challenging issue I had with my new 2015 C400 since I bought it. Had it looked at 5x by two different dealers. Bit of a unique issue and resolution. Possibly a design defect. The issue was with distortion coming from speakers mostly on the passenger side. It was most recognizable when listening to a phone call on Bluetooth or in certain parts of songs where the mids and highs occur. It was quite bothersome to me so I figured it must be fixable. The first 3 attempts to repair were replacing speakers on the passenger doors. Did not fix it. This last attempt the dealer seemed to fix it. Their notes in the service receipt were as follows. Hopefully others find this helpful and can eliminate multiple service visits and frustration.
Noise from front door trim and rear. Door trim speaker covers and clips that hold door trims to door panels. Tried repairing the wood trim panel but didn't fix issue. Replace with new wood trims 72-0000 2.3 72-7156 0.3 72-7156 .03 72-7158 .03 removed both front door wood trim with speaker covers. Added felt tape to all clips and contact points of all door trims.
Old Mar 15, 2017 | 01:38 PM
sunk318's Avatar
2016 C300 4Matic
There is a TSB for this. It is LI72.10-P-061465. This is the fix for the stereo buzz that happens between 220hz to 275hz. I am taking my car in to the dealership this Friday. I hope they can fix it using the TSB. If not, I will defer to your solution.
Old Mar 15, 2017 | 01:46 PM
c400ry's Avatar
2020 AMG GTC
Thanks sunk318. Let me know if that works for you. If my issue comes up again I can have them try the TSB you mentioned as well.
Old Mar 16, 2017 | 03:16 PM
Iggier's Avatar
2016 C300 4Matic Lux w/ P1, P2, Lighting Package
There are two other very informative threads on this topic:
https://mbworld.org/forums/c-class-w...-issues-4.html
https://mbworld.org/forums/c-class-w...-recorded.html
