Replacing tires - question about installation
I've selected MICHELIN PILOT SPORT A/S 3+ tires. My question is can any run of the mile tire shop do it? Is there any worry about the electronics? Like tire pressure sensor, stability controls, e.g.?
This is a 2015 C300 4MATIC Sport.
Also, any recommendation on tire repair kits? The more wife friendly, the better
Slime claims the sealant is safe for the TPMS sensors. Some shops will refuse to mount non run flats on a car that came with them, but I've never run into a problem.
Cause most "flats" are a nail and screw causing a slow leak. The leak are usually slow enough that if you add air to the tire, you should be able to reach where ever you need to get to and get a real fix
Even my Hyundai Genesis and Toyota Sienna has it.
Checked the installers site, they explicitly mention doing services on luxury cars and seem to have good reviews around the net.
Mike - does this look like a good kit? Seems foolproof as well.
Sorry for the amateur questions, i've always dealt with spares before this.
It's basically the delux version. The compressor is fast and quiet. The best features are the added extension for the air hose and the adapter that allows you to connect direct the the battery terminals if needed.
I think you will like the MPAS3+. I've been happy with mine. I've given them a little bit of spirited driving and they grip exceptionally well for an AS tire. They are not as good as the MPSS for true performance but they are equal to the stock OEM summer runflats. They perform great in rain and light snow and ice.
In these situations I usually kindly ask to speak to the manager. At which point I say I have a bad Yelp review with their name on it and I'm not afraid to use it
And in this specific situation, I would inform them that I have roadside assistance and even if I had a flat on the run flats, I would call a flatbed just the same.
OP, how many miles did you get out of your Continentals? They were the all season, correct?
The wear is incredibly uneven between front and back....the back tires look like they could easily go another 20,000 miles.
I only put about 1,000 miles on my Conti's before it was time to put the snow tires on so they're sitting in my storage room until it's time to turn the car back in to the dealer. Not only would I hate to have them wear out that quickly, but they ride/perform like ****.
If you run 30psi in your tires, won't the tpms light be on all the time? Can this system be reprogrammed to a desired level?
Thanks,
Thanks,
Another one of those personal preference things.
