c300 door unable to open from inside, cable too long?
Old May 4, 2017 | 08:31 AM
PATRICKNGO's Avatar
2009 C300
Hi Everyone,
I have a strange situation, my driver side passenger back door unable to open from inside, I thought it is as simple as broken handle, I bought the panel from Ebay paying 150 ..... well the story end up is not that simple... after install the new panel which has a good handle.... it is still not working... the handle pulling the cable a little bit.... but not enough to open the door......
can anyone explain this situation.... I can only explain somehow the cable became longer than it should be......
I did try to fix the broken handle before buying the replacement from ebay by tie the cable to the broken handle using a small wire.... but didnt' work... not sure if I make the cable longer during that process....
Old May 4, 2017 | 08:52 AM
PATRICKNGO's Avatar
2009 C300
I might found the reason by this page
http://www.pelicanparts.com/techarti...el_Removal.htm
it may be I forget to mount the cable to the cable mount.... will go home and try tonight...
on picture 5
Old May 4, 2017 | 09:08 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Gonna throw out the obvious question just to get it out of the way - you're sure the child lock isn't on?
Old May 4, 2017 | 09:10 AM
auditoamg's Avatar
C63s
LOL
Is it plugged in? 😂😂😂
Old May 4, 2017 | 09:33 AM
PATRICKNGO's Avatar
2009 C300
child lock..... yes I didn't check that....
will do that right now going to the parking lot.... but it probably not the case... because the handle is still loose up....
Old May 4, 2017 | 09:39 AM
PATRICKNGO's Avatar
2009 C300
checked it.... it is not the child lock.... after thinking about it a bit more.... it does make sense that not clamping the cable won't work because things should be loosen up... it is one of those things you miss one simple step and everything is not working.... can't wait to try again tonight
Old May 4, 2017 | 12:29 PM
PATRICKNGO's Avatar
2009 C300
Fixed
Did mount the cable onto the clamp
It is working now. Save a few bucks from body shop. Also could have save 150 from eBay using the tie to wire solution. Well happy ending at least
Old May 4, 2017 | 04:44 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
This should be on the W204 forum.
Old May 5, 2017 | 10:27 AM
PATRICKNGO's Avatar
2009 C300
what is W204
sorry, didn't know what is W204, I am driving C300... anyhow... I am new to the MB, just got the car from my wife when she got a new car.... I keep recycling the old one.
