C300 Turbo Upgrade - Partner Needed
Old Feb 9, 2019 | 02:28 PM
  #301
C300AWD's Avatar
C300 4matic
Any updates?!
Old Feb 9, 2019 | 02:47 PM
  #302
Ajagielski's Avatar
2015 c300 2.0t
C300
Originally Posted by C300AWD
Any updates?!
sort of ..I had my c300 at AMR for 2 weeks and during that time they were able to do some dyno sessions and get the tune locked in ....unfortunately I had a meth purge incident that fried the spark plugs previous to the tune..so the dyno numbers came in st 260whp/350tq
after taking it off the dyno they replaced the plugs (which were in terrible shape) and increased the size of the meth nozzle (500cc injector )
but due to extreme cold weather their dyno was down for a few days..I neeed my car back so we were unable to get another dyno session in
im planning on going back in a couple weeks to test the final numbers ..but according to the last dyno session and the change to the plugs and increase in the meth injection we should be right around the 300whp/400tq area
the car is WAY faster than stock and pulls HARD
its holding a consistent 25lbs of boost ..I haven’t done any 0-60 pulls yet but I’m pretty sure it’s in the low-mid 4’s now
final numbers will be posted in a couple weeks ..just to show definitively what we’re making at the wheels
The car sounds amazing though..lots of burble and it’s pretty easy to blow fire out the back when driven in manual shift mode
when it’s under hard boost and the wastegate opens...it sounds badass!
Old Feb 9, 2019 | 07:40 PM
  #303
Hrd_workin's Avatar
2016 Mercedes C450AMG sedan
Hey AJ,
Thanks for the update AJ and congrats again.
Just gaining some more info before ordering everything, with parts and tune for my C450 looking at just about $11K.
Just so that I can understand the C300 is listed stock around 241hp and 273ft-lb. I recall you mentioned you had a tune, down pipes and exhaust correct?
If so, after the upgrades you all are seeing 60hp increase and a big jump in torque.
For some reason in my mind with all of that and the new turbos at a high boost I would think the gains would be greater, right? Am I missing something? Maybe my understanding of hp v.s dyno whp vs crank?
Thanks again for leading the way and any thoughts.
best regards
Old Feb 9, 2019 | 07:46 PM
  #304
Ajagielski's Avatar
2015 c300 2.0t
Originally Posted by Hrd_workin
Hey AJ,
best regards
the c300 is 190hp at the wheels stock with like 200tq
so my 300whp /400tq is a BIG improvement on such a small motor ..and I’m about 8-9k into the upgrade. Probably not the best return on hp to dollar but fun nonetheless. The c450/43 is a great platform for bigger gains
for the 11k you’re looking to spend you’re going to see that you’ll go from about 280wheel hp to almost 550-600wheel hp
after talking with Rob at AMR I’m going to get a c43/450 myself as it’s really a much better platform for huge power.
for the money you’re looking to spend you’ll be extremely happy
I just dropped 45k into my Jeep SRT to increase the power from 450wheel to 900 wheel hp ..so for me it makes Sense to get a c43/450’and for around 10k you can double the power
Old Feb 9, 2019 | 11:09 PM
  #305
redsly's Avatar
2016 C450 (gone), 2018 GLC43 (gone), 2020 GLC43, 2012 ML350, 2013 E350
Not trying to discourage anything here, but I just just recently heard that are "so many 274 engines with melted pistons (at the warranty parts facility) that (they) can barely walk around!" It was then said that "we're seeing this throughout the country (U.S.), EXCEPT in the North East."
I've personally only replaced pistons in them for noise not damage, but have no idea why the NE would be any different.
Instead of waiting on this I upgraded to a C450. Much happier now!
Old Feb 9, 2019 | 11:11 PM
  #306
Hrd_workin's Avatar
Thanks for the explaination; makes sense. Yes definitely a big upgrade from the original 190hp. Gotta be a blast to drive now.
Also makes it a smoother decision to get those parts ordered and started from Turbokits. As I am indeed looking forward to see and feel the next progression in hp increase.
Btw Thats a pretty wicked SRT, congrats.
Thanks again
Old Feb 10, 2019 | 07:07 AM
  #307
Ajagielski's Avatar
2015 c300 2.0t
C450
Acvording to Rob at AMR they do a ton of tunes on the c450/43 cars and have had nothing but great luck with them
I think you’re going to be super happy with an upgrade. I’ll probably play with this c300 for a few more months and then swap out to a c43 or c63 myself
good luck!
Old Feb 11, 2019 | 04:39 AM
  #308
Cartman417's Avatar
Range Rover
good luck!
you are no way a low 4sec car. At BEST maybe mid 4s
and what does AMR or any tuner know about upgrades C43s? There has been no data posted up about them being complete and ready.
If they did any tuner would be boasting how they have upgraded a C43 and show dynos.
575rwhp tops at best. Anything higher and it’s prob in the territory of dangerous tuning as far as timing and AFR running lean.
I find it funny that C63 has upgraded turbos. Now sort of C300 cause no one from what I read on here has a fully tuned and can take theirs out day to day to romp on it. Cause correct me if I’m wrong but you did say yours still isn’t totally done tuned? After what over 2 months?
and yet the C43 doesn’t have anything set either
Old Feb 11, 2019 | 07:50 AM
  #309
Ajagielski's Avatar
2015 c300 2.0t
C300
mine is fully tuned..it took a while because we had a mechanical boost leak that was hard to find..and I had to get my car back so that has stalled the tuning. It’s fully tuned now and runs fine as a daily driver
I beat the snot out of it and it runs great
You also have to realize that my c300 is the first big turbo that AMR has really messed with so it took some time to develop a tune that was safe and reliable without disabling any of the factory ecu safeties that are built in.
now that mine is tuned they can send a tune for this upgrade out in a handheld Programmer I’m pretty sure
You may be right though about the 0-60..it’s most likely mid-high 4’s ..we’ll see though when I get around to finding someway to test it
as far as the c43/450 ..you’re misinformed..AMR has upgraded turbo kits and has tuned hundreds of them..if you are skeptical you should call amr and talk to then
they’re making huge power from them
oh and by the way ..according to AMR they can tune a bone stock c43 and reduce the 0-60 from 4.3 to a 3.0 sec flat with just a tune
so it sounds like they have something figured out
Old Feb 11, 2019 | 12:16 PM
  #310
Cartman417's Avatar
Range Rover
Not trying to be a dick but sounds like you are misinformed. Their tune and no ones tune takes it down to 3.0. Not even close. That would suggest an almost flat 11 with just a tune.
And i I will contact amr because there’s no way they’ve done hundreds of C43s or C450s and there hasn’t been one post about it from anyone. I could see if there were enough that you could count on your fingers on one hand but even then that’s doubtful. I’ll message them and report back
Old Feb 11, 2019 | 12:20 PM
  #311
Cartman417's Avatar
Range Rover
Now if you just meant tuned hundreds of C43s. Ok. But not upgraded turbo ones
Old Feb 11, 2019 | 12:34 PM
  #312
Ajagielski's Avatar
2015 c300 2.0t
C43
yes..they’ve tuned hundreds but have also done a bunch of turbo upgrades on them also
call Rob at AMR and talk to him
he’s the one who told me a tune will get it to 3.0
Old Feb 11, 2019 | 12:42 PM
  #313
Cartman417's Avatar
Range Rover
Well he’s for sure bull****ting right there cause I know the 2 fastest C43s and they’re JB4 tuned and they run 3.2 or its 3.3 0-60
This is fastest that someone has actually posted proof of. If he says 3.0 he should prove it in my opinion
Old Feb 12, 2019 | 11:11 PM
  #314
ItalianJoe1's Avatar
2003 CL 600
Fuel quality. They melt down the front of #1 piston due to detonation when people run poor fuels, the protection strategy in the M/E isn't aggressive enough for the cheap gas and the way people drive.
Old Feb 13, 2019 | 12:36 AM
  #315
redsly's Avatar
Thanks for the info!
I figured it was cheap gas causing detonation, but didn't know it was cylinder #1. Coincidentally enough, that just happens to be the only cylinder I've personally seen misfires in and that's only been a few times.
Foreman passed the aforementioned information recently while I was replacing pistons, so I only got what was reiterated.
Old Feb 15, 2019 | 11:33 AM
  #316
suby01's Avatar
2024 AMG GLE 53
Are you talking about buying cheap quality fuel as from Costco, Citco type brands? Or also low octane someone putting in 87?
Old Feb 15, 2019 | 05:02 PM
  #317
redsly's Avatar
I assumed lower octane, because detonation can happen at higher compression ratios if you don't increase octane rating.
The octane rating SHOULD be the same throughout the market, but we all heard of some places having contaminated, water, etc. in fuels and that is a different story.
@ItalianJoe1, do you know if this is seen more in vehicles that they removed the low-temperature coolant circuit from? I was wondering if that had anything to do with it after I heard about them detonating.
Old Feb 20, 2019 | 09:03 AM
  #318
suby01's Avatar
2024 AMG GLE 53
Hey Ajagielski so if your car complete? The AMR tune and the Turbokits turbo working together correctly? Any other insight you want to share?
Old Feb 20, 2019 | 11:18 AM
  #319
Ajagielski's Avatar
2015 c300 2.0t
C300
so far everything is perfect
car runs and drives great with lots of power compared to stock
the boost comes on fast so it pulls much harder down low compared to stock turbo
I’ve got about 500 miles on the tuned setup. I do use a pretty fair amount of meth though so if you do this setup be prepared to buy a ton of meth. I’ve been ripping through it so fast that I ended up just buying 20 gallons of it last week so I don’t run out
l’ll be heading back to the dyno in a few weeks though just to make sure everything is running perfectly as well as verifying the numbers again
Old May 14, 2019 | 03:28 AM
  #320
Hrd_workin's Avatar
Hello AJ,
Hope this finds you well.
Been sometime, how are things running with the turbo and meth setup since you put 500 miles on it last?
Have you been able to get your final dyno numbers yet?
Appreciate the feedback
Best regards
Old May 18, 2019 | 12:23 AM
  #321
C300AWD's Avatar
C300 4matic
Very curious as well!
Old May 24, 2019 | 01:04 PM
  #322
Joey Choo's Avatar
w205 c200
Originally Posted by TurboKits.com
Hello All, here is the before and after on our first round of testing. Keep in mind this is a 100% stock 2015 C300 4Matic for the before and ONLY the turbo upgrade and tune after. As we mentioned in the previous post, the top end is suffering from the exhaust restriction. Imagine if you will that the HP stays on an upward trajectory and you can envision about where it will be once the restriction gone. Anyway, we have 2 test cars now on the list, so we should be able to show you our round 2 results shortly. Thanks for following!
Is this the result of stock C300 with turbo and methanol upgrade? Is there any updates on this turbo yet? 0-100? Dyno with full exhaust and intake setup?
Old May 24, 2019 | 03:14 PM
  #323
TurboKits.com's Avatar
SPONSOR
2014 CLA 250
Hopefully soon, final DYNO booked in 2 weeks for a C300, Turbo Back Ex & Water Meth with our Turbo Upgrade and AMRs prototype tune!
Old Jun 25, 2020 | 12:54 AM
  #324
SLOBENZ's Avatar
c300 4 matic turbo w205
Thumbs up
Originally Posted by jaseng
Turbokits, do you have a front mounted intercooler upgrade yet for the C300?
honestly we need one for the w205 community
Old May 19, 2024 | 05:32 PM
  #325
Ryordanov's Avatar
2016 Mercedes C43 AMG
C43 AMG Build Series
Hello lads,
After thorough research on upgrading turbos, intercooler, high-flow cats, tuning, general maintenance, and everything in between for a C43 AMG, I've made the decision to launch a dedicated YouTube channel for these topics. If you're keen on learning or following my journey, feel free to check out my channel using the link below:
https://www.youtube.com/channel/UCdr...confirmation=1
Thank you for your interest!
