DIY Replace c300 brakes
Old Sep 24, 2017 | 06:00 PM
Hello32's Avatar
C300
my car just hit 30k and i feel a vibration on the road when im pressing the brakes leading me to think by pads and rotors are going out. I have been able to find DIY for C63s but not for a regular c300 Amg model. Does anyone know the proccess? my father is a mechanic and wanted to show him a tutorial video? thanks
Old Sep 24, 2017 | 06:29 PM
ItalianJoe1's Avatar
2003 CL 600
If he's a mechanic, and he's ever changed brakes before, he should be fine. There's no magic to it.
Old Sep 24, 2017 | 06:57 PM
Hello32's Avatar
C300
just wanted to see if their any extra steps, i saw a video on youtube where they press some buttons on the steering wheel to push out the breaks, was just wondering if anyone had any tips or a video of this, thanks
Old Sep 24, 2017 | 07:22 PM
2003 CL 600
That's only for the rear, you have to release the electronic parking brake so you can push it back.
Old Sep 24, 2017 | 07:29 PM
Hello32's Avatar
C300
would you recommend replacing the front and rear at the same time? and to push the parking break we just do the steering wheel controls correct? thanks for your help
Old Sep 24, 2017 | 07:31 PM
2003 CL 600
Only replace what's worn down, the fronts normally wear much faster than the rears, if the rear is fine, leave it be.
Yes, you need to go into the service menu, and use the selections to move the parking brakes to service position if you intend to compress the rear calipers to fit new pads.
Old Sep 24, 2017 | 07:50 PM
Hello32's Avatar
C300
so just to make sure if im only changing the front pads and rotors, i do not need to touch the steering wheel controls correct? only the rear require service position?
Old Sep 25, 2017 | 06:37 AM
Greg52's Avatar
W205 C250
Myself and I think others on this forum have observed that the rear brakes seem to wear more quickly than the fronts. I have owned and maintained many vehicles but this is the first that I have had that does this, some have suggested that the cause is the stability control system.
If you need to replace the rears then there are video instructions on YouTube on how to access the maintainance pages and then electrically retract the caliper
Best of luck, I'll be doing mine sometime soon too
Old Sep 25, 2017 | 12:46 PM
Hello32's Avatar
C300
ive only been able to find videos for c63s on youtube, does anyone have one just for c300
Old Sep 25, 2017 | 02:03 PM
PelicanParts.com's Avatar
SPONSOR
Agree, only replace what needs to be replaced. Inspect your rears and see how much life is on them still. No need to replace them if they have plenty of meat left. I do rotors and pads to compliment each other at the same time. We don't have any W205 tutorials, but if you need any parts assistance please let me know. If you do document the process we would love to add it to our technical library, and even give you a discount on parts if we use it. More info here: http://www.pelicanparts.com/support/...ubmissions.htm
http://www.pelicanparts.com/catalog/...05_catalog.htm
Old Sep 25, 2017 | 04:46 PM
Greg52's Avatar
W205 C250
Old Nov 1, 2017 | 11:46 PM
TheeNando's Avatar
2015 Mercedes C300 4MATIC
What brake pads did you end up using? Anyone know if brake pads advertised for 2015 c350 work for the 2015 c300?
Old Nov 2, 2017 | 02:54 PM
fabbrisd1's Avatar
A gaggle of MB's
No.... C350 brake pads do NOT work for C300 - and for your 2015 C300 there are TWO different brake pad sets depending on sub-model - so check with MB part dept for correct MB part # - then shop for correct equivalent
Old Dec 8, 2017 | 06:12 PM
Hello32's Avatar
C300
everytime i try to disengage the parking break i get the message Conditions not satisified press ok to retry, and it doesnt work, anyone know the problem?
Old Dec 8, 2017 | 06:34 PM
TheeNando's Avatar
I had that message come up when I had my parking brake engaged. I thought it was messed up because my parking brake light was On but the brake wasnt ACTUALLY on. I fixed it but having the car roll a bit (2-3mph), then flicking on the parking brake switch. I think that moved things in place because I was able to then actually disengage the parking brake and the light cleared. weird stuff.
Old Dec 8, 2017 | 06:42 PM
Hello32's Avatar
C300
was that when you were trying to replace the breaks? im trying to change my breaks and got to the menu were you rchoose caliper service position but it just wont go
Old Dec 8, 2017 | 07:23 PM
TheeNando's Avatar
This was after I had a dealer replace my rear brake pads for free.
Some reason the parking brake light came on and wouldn’t go back off until I did what I mentioned above.
The mechanics like using the computer tablet thing that I’m not sure what it’s called. I had to go to three different mechanics until one of them had an up to date tablet to disengage the parking brake. I told them about the way to do it shown on the YouTube video, but they insisted of using the computer. I think that’s what messed it up once the rear brake pads were replaced. Lucky I was able to fix it. I definitely recommend taking to the official Mercedes dealer if your is 2015 and up and can’t figure it out.
Do do you get any messages on your dash when you start the car? Also, do you have the parking brake on when you’re trying to do it?
Old Dec 8, 2017 | 07:46 PM
Hello32's Avatar
C300
I dont get any message when i start or anything i was just trying to change my nrakes and rotors, got the front done no problem and thought i would be able to do it the youtube way but it looks like ill have to take it to the dealers
Old Dec 8, 2017 | 10:29 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
ARE you sure you are driving w205 and not a w204
Old Dec 9, 2017 | 01:20 PM
RemmyZero's Avatar
2016 C300 4matic
I just did mine last weekend and after watching a video online I was able to manipulate my parking break without any issues. I'm really not sure what caused your issue but at least you figured it out.
Old Dec 9, 2017 | 03:18 PM
Hello32's Avatar
C300
after trying for about an hour it randomly worked, didnt do anything different
Old Nov 9, 2019 | 04:00 AM
junichi's Avatar
W205
I had the same issue and found a correct procedure as follows. I have added step 1.1:
1. Turn the ignition to Position 1.
1.1 Release the parking brake, if it is active
2. Make sure the mileage is displayed in the dash center window
3. Don't wait very long before accomplishing the next step: Push the far right "telephone accept call" button on the steering wheel, then push the "OK" button on the left and hold both down for 5 seconds or so.
4. The workshop menu should appear.
5. Scroll down to "Pad replacement" and push OK.
6. Choose OK for "Moving to fitting position"
