Cost to change transmission fluid C300 4matic?
https://blog.fcpeuro.com/mercedes-7-...-transmissions
Genuine MB Tranny Fluid:
https://www.fcpeuro.com/products/mer...d-001989780309
https://www.fcpeuro.com/products/mer...tosin-7229late
Edit, this too:
Anything that requires payment from me that I can't do myself is done at an independent shop, except for my first service done at a MB dealer which was the last time I did that (got totally ripped-off).
Also, for those that don't know, getting service done at an independent shop does not void your warranty (if you still have one).
https://www.yourmechanic.com/estimat...-fluid-service
Sediment tends to settle low (gravity) and finds a "home" to build-up in small quantities (in a healthy tranny). I'm not sure why anyone would want to stir that up and run it through the entire system.
I've never had a vehicle of mine get the tranny flushed, so I don't have first-hand experience, but I've come across many horror stories of tranny issues after flushing.
Just FYI.
Just FYI.
When i say transmission flush, i meant any and all activies needed to correctly replace the transmission fuild cleanly.
If a "flush" is not part of the normal transmission fluid change then its my fault.
Good luck man!
I thought that we already all knew that stealers are scammers and that we had never trusted them EVER !
