Memory car seat not working
usually the technician, manually moves my seat forward or backwards disabling the memory seat function. In the past I've taken it to the dealer and they've done something to reset the program.
When I manually push the seat adjustment button forward...the car seat moves forward a few inches and then stops.. I again have to depress the button and it moves up a few more inches. I essentially can't adjust the seat using any of the
three memories and can't store any settings,,, but I can manually adjust my seat using the buttons. The steering wheel still moves out of my way when I enter or exit the vehicle .. so I'm not sure if this is the same issue as the
easy entry/exit feature (I've tried that reset protocol before).
Any help would be appreciated..
Does anyone know what the dealer does to reset seat?
I don't think anything is broken. Is there a reset we can do?
Dealer want 170 just to look at it...
while you’re doing this you’ll notice the seat will only move slightly then stop. You will have to keep pressing until you reach the end of each direction. Once you do this you will see that the movement will no longer stop and go uninterrupted until the end of the track. Once you get all the functions moving freely without stopping the memory buttons should once again move the driver seat.
p.s. I drive a w213
p.s. I drive a w213
p.s. I drive a w213
p.s. I drive a w213
p.s. I drive a w213
Sorry if this reply revives an old thread, but the whole "relearn the range" thing helped my 2025 new vehicle. The passenger memory controls would beep like it remembered the settings, but recall did not work. Manually adjusting the seats worked fine.
I was about to take it to the dealer for help, but after reading this post, I figured it was worth a try.
Up down left right backward forward on every adjustment available and the seat recall just magically started to work. Not sure why this is needed, but it works. Ty!
