LED door handle light replacement
Old Mar 31, 2019 | 09:37 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by Elbandito
were you able to find anything for the door handle lights? I looked and couldn’t find
still looking. but I found this for my next project.
https://mbwis.net/en/doc/7073710
Old Mar 31, 2019 | 09:43 PM
benzdude's Avatar
Top Answer: 1
all I found on door illumination was this.
Old Mar 31, 2019 | 10:25 PM
Jack_88's Avatar
2018 C300
Originally Posted by benzdude
I just found this and it's open
https://mbwis.net
That will be bookmarked for me for sure, faster than opening the virtualbox!
Old Apr 1, 2019 | 11:55 PM
pussgalore's Avatar
na
I thought I was the only one with this issue! I refuse to pay $700 to have it fixed.... maybe indies can replace the LED if there’s a WIS.
Old Apr 2, 2019 | 12:03 AM
Jack_88's Avatar
2018 C300
Heck, I don't trust mechanics anymore if I have a choice, I've been victim too many times. The only issue with door panels is there are often plenty of delicate clips and trim pieces, so removing them has to be done carefully. These cars are new enough that embrittlement shouldn't be an issue.
Old Apr 2, 2019 | 11:01 AM
benzdude's Avatar
Top Answer: 1
it doesn't look like there is an official WIS document for "remove/install door handle led"; however. you can click on the MBWIS link and get the separate instructions (and related docs) to do the following:
1. Remove/install the door trim
2. Remove/install the window glass (easier than I thought)
3. Remove/install door handles
Once those are done you can access the $15 door led. *sigh* then Install in reverse order.
PRO TIP: use chrome browser which has a save/print to PDF built-in to save the docs to your computer.
By the way, removing the door trim is actually the easiest part.
I may do a DIY led install myself later.
**Sample attached**
EDIT: I actually have to remove my passenger side door lining today to swap my aftermarket spinning tweeter (back to OEM), before I bring my car in to get the door led fixed. I don't want the tech to accidentally damage it if he needs to remove it for the led install.
Old Apr 2, 2019 | 11:19 AM
  #32
chrisdean's Avatar
W205 C200 AMG Line Premium
The window regulator panel must be removed completely as the led housing is built into its reverse side and this means disconnecting the wiring harness to the door. Even with the regulator removed getting the old led out is a bit fiddly so would be impossible in situ.
Old Apr 2, 2019 | 11:29 AM
  #33
benzdude's Avatar
Top Answer: 1
do you mean this? (front driver side door)
Old Apr 2, 2019 | 02:07 PM
  #34
chrisdean's Avatar
No, not the white item arrowed, the entire black panel must come out so you must also detach the wiring harness at the A pillar. The LED housing is built in to the rear of the large black panel.
Old Apr 2, 2019 | 03:03 PM
  #35
benzdude's Avatar
Top Answer: 1
I ran out to the dealer to get a copy of my last led removal invoice. Here it is. The tech put in lots of notes.
#6 A099-820-01-83 light control element
They could easily redesign this so the led bulb and base are separate. Then all you do is remove the door handle and pull the led out of the base and insert a new one. Issue solved.
Old Apr 2, 2019 | 03:18 PM
  #36
benzdude's Avatar
Top Answer: 1
Video on how to remove door panel.
Old Apr 2, 2019 | 03:22 PM
  #37
chrisdean's Avatar
Or they could have chosen better quality bulbs that didn't need replacing!
Old Apr 2, 2019 | 03:49 PM
  #38
benzdude's Avatar
Top Answer: 1
There may be better leds that last longer, but I don't think any led will last forever.
Old Apr 2, 2019 | 05:01 PM
  #39
Skim450's Avatar
C450 AMG - Polar White
looks like a terrible design..... all that work to change one little LED door handle light. that is silly.
but hey what do i know, i sit at a desk and input data all day. not like i could build a car better myself...
Old Apr 3, 2019 | 03:24 PM
  #40
benzdude's Avatar
Top Answer: 1
Just got back from the dealer and had my two doors done. I asked service guy for the WIS sheet and he said there isn't one for the "removing and installing door handle leds" (like I said).
However, the tech just printed up the following sheets:
  • remove/install front door lining
  • remove/install back door lining
  • remove/install crank window in front door
  • remove/install door module
  • remove/install door rear module
All available here: https://mbwis.net
Old Apr 3, 2019 | 05:43 PM
  #41
pussgalore's Avatar
na
deleted
Old Apr 3, 2019 | 06:47 PM
  #42
benzdude's Avatar
Top Answer: 1
deleted
Go here:
https://www.datamb.com/
Enter your vin and look at car info on top of page
Old Apr 8, 2019 | 12:07 AM
  #43
vanondemand's Avatar
BMW
Had 3 of my handle lights replaced under warranty without question.
Old May 14, 2019 | 05:27 AM
  #44
Tintin124's Avatar
C Class W205
I've had 1 light changed under warranty but the colour/hue is completely different to the other handles (other handles being a blue/white tone) with the new one being yellow.
According to service centre they think that Mercedes have upgraded the LED bulb to a more durable one but part number has remained the same. Just a pain that I have to go back and either get 1 re replaced or 3 replaced, just appreciate that its on Warranty.
Old May 14, 2019 | 12:47 PM
  #45
benzdude's Avatar
Top Answer: 1
Yellow led (warm white) might be ok and may just mean a different led temperature (around 4500k), but is not a good look for a premium Mercedes Benz. IMHO.
Cool white leds around 5000k (actually looks very white, tiny tiny hint of blue) is what is desirable, but are not provided. My car is diamond white and i can see the yellow light from my handles.
MB may have replaced the hotter cool white leds with warm white to circumvent the burnout issue.
Old May 14, 2019 | 02:40 PM
  #46
Tintin124's Avatar
C Class W205
Mine is also Diamond white, which is why it's a shame the new one is so yellow in comparison to the others. If they cant get the same one as originally on the handle then they are going to replace all with the new lights 😢
Really doesnt look great against the white.
Old May 14, 2019 | 03:22 PM
  #47
benzdude's Avatar
Top Answer: 1
My dealer wouldn't replace any led that wasn't completely defective. Temperature difference wasn't considered a defect.
Old May 14, 2019 | 03:36 PM
  #48
Tintin124's Avatar
C Class W205
I had one blown whilst under warranty and as colour didn't match, I complained they are going to check new one is not faulty. They need to check the part number/serial of old unit to new. If the new one if different they will replace the other 3 with the yellow ones 😢
Old May 15, 2019 | 03:24 AM
  #49
Tintin124's Avatar
C Class W205
New version
Original blue hue
Old May 15, 2019 | 07:40 AM
  #50
benzdude's Avatar
Top Answer: 1
New version
Original blue hue
That blue to purple color means the led is going bad. Its hard to tell ithe exact color n a picture due to camera settings. Is it deep blue/purple looking?
Top picture is what the newly replaced leds look like for me.
