LED door handle light replacement
Also the cheap LED can't be replaced without the complicated labour as noted above. This is really disappointing. I just hope all 4 die at the same time now and I can live without it
https://mbwis.net is saying refused to connect.
Locked now?
Specifically need the
- remove/install door module
2 fronts were replaced about 6 months ago under warranty, now my warranty has expired.
Got 1 out in the rear and the other side is blue and on its way out.
Locked now?
I just noticed at 3:08 the led can be accessed/removed at the outside door handle on this W213.
