Question about mystery noise when turning on incline/decline
So have been trying to figure out this mystery noise in my W205 sedan. The best way I can describe this noise is when coming down or going up my basement parking ramp and then while turning / or straightening the car into the underground garage or up on the main road, a single click sound comes just like when you crack a single knuckle on your hand.
Observations:
It doesn't happen every time but frequently. No noise when on level roads at all, just when turning and some inclined or declined pavement.
Initial work:
Took it to the garage last week, and we discovered the lower control arms needed replacing / bushes so new pair installed, and alignment done. Noise less frequent and bit fainter but stlll there in same driving conditions. We were hoping that this would have removed the noise as well, but its still there.
Any idea what this could be? I don't think its normal, but the whole suspension system was checked and today rechecked and its all fine. Annoying more than anything else on a $50K car, so any advice from anyone who experienced this would be very much appreciated! 2016, Mileage 60,000 KM. Major servicing done about 1200 Km ago, nothing unusual noticed, and just brake work and usual stuff in the servicing by dealer. Mounts all were fine as well, CV joints fine.
I think they checked the sway bar link as well and was ok, not 100 % sure tho.
Not sure what the issue is, it even persisted after I had spacers installed plus an alignment.
Mine is not a 4Matic, so I know it's not a front axle/CV joint. Will have to give the FSB a look & see if that may be it.
Yours does sound like the strut though, but if it is still best to take back to dealer and recreate it and tell them issue not solved. I am facing the same situation after having replaced lower control arms at my cost, which it was broken anyway. But this flex noise is just pissing me off. Not going to pay a cent more, dealer better fix it as they charged me enough labor.
It's actually quite discomforting, but I know it'll be nearly impossible to reproduce, short of having a mercedes tech spend the night and drive your car to work the next morning.
It is music not hearing those annoying flex/crack sounds when on inclines!!!
What is the mileage on your car? Mine is just 60,000 KM.
im in Australia with bad roads and the vehicle only has 20,000Km on it. Hasn't even had the first service yet.
Mystery, but now I cant bug dealer without the sound. Its been few days not a peep in the same inclines (my garage).
