retrofit rotating tweeters (burmester copy)
Turns out the top window glass seal slides out of the door panel and can clip back together with some pressure after you have it aligned correctly.
1. Disconnect #6 connector from door controller and plug it into the harness, then plug the harness into #6 port.
2. Disconnect tweeter 2 pin cable, plug into Y harness cable to new 3d tweeter.
3. Spend 5 hours trying to put left door panel back on with speaker installed.
(realize your mistake)
4. Spend only 40 minutes on entire right door speaker install.
I had to first reroute the existing mirror cables (try not to bend the fiber optic cables) to the left and right sides, and then mini zip tie them in place. This made the install easier.
Congrats.
Cranberry red leather. Thanks! One of the main reasons I bought the car. It’s a 2015.
You should play a good tweeter song and compare them with the back tweeters. Hop in back, stick your ear close.
my tweeters is for the W205 C180 have an extra 4 pin plug i have no idea were to connect this plug
i got the tweeters to work and every thing motor working fine but no light ,
Did the seller confirm your car year, model and number of ambient package colors, if any? Not all aftermarket 3d tweeter kits are the same.
Is your car a 2015 w205 with factory 3 color ambient?
i confirmed with them the model
i cant find a place to plug this extra 4 pins
