retrofit rotating tweeters (burmester copy)
Old May 18, 2020 | 05:31 PM
  #76
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Upgraded my rotating led tweeters to Audiotec Fischer Match tweeters
Old Jan 12, 2021 | 01:37 AM
  #77
myonoshane's Avatar
Lexus IS350
Hey benzdude! Nice build and thanks for the info about the tweeters. Just wondering how they've kept up after having them in for over two years? I'm about to go ahead with purchasing some but given they're from China i'd hate to have them in for a year before having to replace them again.
Also when you replaced it with the Audiotech tweeters, were you essentially removing the 3D rotating tweeter?
Old Jan 12, 2021 | 11:03 AM
  #78
benzdude's Avatar
Top Answer: 1
The chinese tweeters sounded ok, worked fine.
As i mentioned before i accidentally destroyed one by squeezing the wires together and bypassing the crossover.
Since the Match tweeters are the same sizes i took the opportunity to replace both. They sound incredible.
My 3D rotating tweeters work the same as before.
The body rotates and the tweeter sits inside. You just need to make sure you put it back together properly and enough loose wire is available to allow it to spin.
Old Jan 21, 2021 | 06:10 PM
  #79
BayAreaAMG's Avatar
2016 C450 AMG
I am getting ready to install all of the ambient lighting retrofit this weekend. I haven't looked at it in great detail yet, but how did the included tweeter become removed so that you can install the Match tweeter? I am guessing the 3 main screws holding it down need to come out.
Old Jan 26, 2021 | 04:35 AM
  #80
pablitoito's Avatar
MERCEDES CLASE C 220 W205
PRO TIP: don't be stupid like me and spend hours trying to get the door panels back on with the rubber window glass seal attached.
Turns out the top window glass seal slides out of the door panel and can clip back together with some pressure after you have it aligned correctly.
Hello friend, I am also installing the Twetter 3d, I have removed the door panel, how do I place it now? I can't fit the panel
Old Jan 26, 2021 | 04:40 AM
  #81
pablitoito's Avatar
Looks like there is also a mid speaker cover illumination kit. (taps into the same #6 connector)
https://www.ebay.com/itm/Mercedes-GL...r/223193738670
Hi, I'm going to install the led speaker covers, how do I remove the original door panel covers to put the led on? Has anyone tried?
Old Mar 31, 2021 | 03:25 AM
  #82
PaulR7's Avatar
W205
Hey @benzdude , sorry to be a pain and revive an old thread but I just got those and trying to get my Match tweeters in there but I seem to have trouble getting the original one out, do you remember how you got yours out by any chance?
Old Mar 31, 2021 | 10:30 AM
  #83
benzdude's Avatar
Top Answer: 1
For the best results, you need a set of these. They are handy in various DIY situations.
The tweeter mount all have lock notches and may have a bit of loose glue to keep tweeter in place. (I guess it depends on your rotating tweeter manufacturer)
See pics below.
Just gently pry apart with tools and they should pop out easy.
Reuse the tweeter mounts.
Old May 6, 2021 | 02:00 AM
  #84
benzdude's Avatar
Top Answer: 1
My LEFT tweeter went out today, so I pulled it and did some tests.
Looks like the ATF MATCH tweeter wires are too stiff to rotate back and forth forever (I had suspected as much, but thought I would be fine)
I will need to replace one inch of wire on both tweeters with softer wire that can rotate and bend with no issues. Hopefully the tweeter is OK.
Old May 10, 2021 | 07:46 PM
  #85
jherm's Avatar
C63S
I just ordered these and communicated with the seller prior to purchasing with the exact version that I need. I think I may have still received the wrong version, but would appreciate if anyone who has done this swap could help.
I have a 2016 c63 with stock 3-color ambient light.
What I received looks like this:
From reading a few of these threads and watching this video installing on a 2016 w205 (
), I think the 3-color version that I need has the extra cable as seen in the pic below and that video points to at 1 min 37 sec. He identifies that as the cable for ambient light on that 2016 (like mine) and I don't have it.
So was I sent the wrong version (64-color) or am I missing something?
Old May 10, 2021 | 07:57 PM
  #86
PaulR7's Avatar
W205
From reading a few of these threads and watching this video installing on a 2016 w205 (https://m.youtube.com/watch?v=qZrXvFrxFfA), I think the 3-color version that I need has the extra cable as seen in the pic below and that video points to at 1 min 37 sec. He identifies that as the cable for ambient light on that 2016 (like mine) and I don't have it.
If you received the same as in video that'd be wrong, in that video he's installing a complete aftermarket kit, I'm not sure what you've received as the pic resolution isn't that great but it looks similar to mine which is completely aftermarket ambient light system and iirc would be a different connector than for original one.
Old May 10, 2021 | 08:06 PM
  #87
jherm's Avatar
C63S
Yes, in that video he's installing the kit also including the door speakers which I don't have. Was just using the video because he clearly describes each of the tweeter cable functions. And that was a 2016 like mine. Between that video and reading a few threads on the topic, my understanding was that the version with the extra cable is for stock 3-color ambient lighting and the version without the extra cable is the 64-color. But each thread was a bit confusing so I could be mistaken.
Also, I think you confused which picture I said I have. It's not the lower resolution one. What I received looks like the first picture that is higher resolution.
Old May 10, 2021 | 08:55 PM
  #88
PaulR7's Avatar
W205
No I didn't misunderstand, both pictures are very low resolution, the second just more so. In any case, have a look at that white plug, if there are 4 pins there then you have received the 64 colour version.
Old May 10, 2021 | 09:18 PM
  #89
jherm's Avatar
C63S
Ok, below is my actual harness. There isn't an open white plug. There are two white parts already connected to each other...?
Old May 10, 2021 | 09:32 PM
  #90
benzdude's Avatar
Top Answer: 1
The small cable is for audio.
The large cable is for power, etc. It needs to be a T harness because you will be unplugging a large connector from the door controller and plugging it into your harness. Then take the other end of your harness and plug it into the door controller. Simple. They should all fit each other.
Hope he sent you the correct 3 color version.
Old May 10, 2021 | 09:43 PM
  #91
jherm's Avatar
C63S
So does that picture look like the setup I need for 3-color? It has the small audio cable. And then 2 larger cables coming out of the speaker that feed into the top and bottom of the white connector. And there is another white part inserted into that connector. That white part has two cables with one going to the black box and the other to the larger blue connectors. Which then is wired to the black box as well. It's like a loop except for the two larger blue connectors.
So the only open connections I have (that can be plugged into car) are the 2 small blue connectors for audio and then the 2 larger blue connectors. Is that right for 3-color? In the video there is an additional cable that he shows also plugging into the car and said that is the ambient light cable.
Old May 10, 2021 | 09:58 PM
  #92
PaulR7's Avatar
W205
Ignore the video, you should have a completely different harness if you're plugging it in to the original ambient light and you do.
I'm not sure where the MCU sends the original ambient light info over but it very well might be through plug #6 in the door control module.
Simplest thing would be to plug it in and try to see if it works, undoing the door card is honestly a 5-10 minute job.
Old May 10, 2021 | 11:14 PM
  #93
benzdude's Avatar
Top Answer: 1
He is making this way too complicated when every connector is sized, shaped and notched to only fit correct sockets.
Old May 10, 2021 | 11:20 PM
  #94
benzdude's Avatar
Top Answer: 1
Nobody can tell you if you bought or recieved the correct product for your car from a picture.
Not all kits have the same wires or requirements. Yours appears plug and play. Many require soldering to existing wires.
Try it out, you already spent the money. ​​​​​
Old May 12, 2021 | 11:33 PM
  #95
Endless Automotive Admin's Avatar
Former Vendor of MBWorld
From the picture, that looks to be 12 or 64 color version.
3 color doesnt have module boxes like that.
Old May 12, 2021 | 11:45 PM
  #96
benzdude's Avatar
Top Answer: 1
Mine did. The module box is needed to interpret the #6 plug signals on/off/etc and color choices.
Old Jun 14, 2021 | 12:03 PM
  #97
Moe777's Avatar
W205
Unhappy Helpp
Hey everyone,
In early 2015 models, port 6 does not have all pins, causing it not to rotate, everything besides that works, anyone know a way to fix this?
Old Jun 14, 2021 | 12:14 PM
  #98
benzdude's Avatar
Top Answer: 1
Originally Posted by Moe777
Hey everyone,
​​​​​You may have to use a ACC wire to trigger rotation?
Old Jun 14, 2021 | 12:19 PM
  #99
Moe777's Avatar
W205
thanks for the reply, i was thinking of soldering my own pins on the door module but that probably wont be of any use since no power would be going to them pins?
weird thing is I’ve heard someone say it worked for them
Old Oct 5, 2025 | 02:59 PM
  #100
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Noise?
I ordered a pair. They arrive today.
just curious if there’s any noise or if the rotation is a little clumsy or off.
What’s the quality like?
