Best option to renew live traffic on audio 20
Old Nov 27, 2018 | 06:33 PM
Murton's Avatar
W206 C300e AMG Line Premium Plus with driver assistance package
I have just bought a 2015 C200 with satnav and audio 20 so it has the sd card and no command online.
Live traffic has expired as expected given the age and I believe the only way to renew it is to get a new map sd card which will come with another 3 years online traffic.
Is this only available from the dealer or is there a cheaper source?
I am used to running Waze which I like but I would want to install a power cable for the phone which is hidden away. I tried the satnav tonight which worked ok but the instructions were a bit off. Telling me to keep left along a road which was only one lane in each direction for example.
The quality of the map was not that great either. Twice it told me the wrong exit from a roundabout because the map didn’t have the car park or industrial estate exit although it has been there for many years.
i did download the utility and it upgraded the software from version 4 to version 6. Will test to see if that is any better.
Old Nov 27, 2018 | 11:00 PM
pete_w's Avatar
2015 C300 4Matic
You didn't say where you're from, but maps in the US are up to version 11 or 12 I believe. They did transition to a larger capacity SD card around version 8 too.
You have a couple options:
1. Stick with the old maps and call SiriusXM to setup a traffic only account (approx $5/month)
2. Buy a new SD card to get the latest maps. I bought from https://www.ebay.com/usr/dbrandshop?ul_noapp=true for $150. The new card included 6-months of traffic. I have since renewed my SiriusXM package and traffic started working again without any issues.
Old Nov 28, 2018 | 02:21 AM
Murton's Avatar
Sorry forgot to say I am in the UK
Old Nov 28, 2018 | 03:32 AM
guhvies's Avatar
2017 C43 AMG Saloon
If you're using the satnav in the car, you'll need to update the maps. I believe Ebay might have them. Search the forum to see how folks have run wires to power fones. As you're used to Waze, this is really your best bet.
Old Nov 28, 2018 | 04:26 AM
Murton's Avatar
Thanks. I read elsewhere that although you can get updated maps off ebay the live traffic feature doesn't work on them. Has anyone tried this or can recommend a good UK seller?
Old Nov 29, 2018 | 08:21 PM
RixC300's Avatar
2015 C300/ 2014 Ford Expedition 2012Ford F205 4x4
I understand using the OEM screen but Waze is hard to beat.
Old Nov 30, 2018 | 11:28 AM
Murton's Avatar
Dealer quoted best part of £500 for a new map and actually suggested I check ebay.
Waze it is then. I have plans to run 12V from the fuse box in the boot to a slimline 3A USB supply. Then hide the supply behind the dash or in the pillar so it is nice and close to the phone so I can use a short USB lead. The problem with running a USB cable direct from the boot is that although fine for a dashcam when charging a mobile it will have quite a bit of resistance so the phone won't charge up as quickly. I have had issues with cheap cables where they cannot even keep the battery from draining when using Waze so a longer cable is likely to be worse.
Old Dec 1, 2018 | 11:00 AM
Luton Driver's Avatar
C Class 200 sport petrol auto
I was lucky as both the dealer and I thought the audio 20 had 3 years of free updates. After the initial 60 day window to update I would always get a message that I had the latest maps. After a year I had a moan at the dealer who gave me a new SD card in sealed packaging. I was going to use it straight away but hung on to it for a further 2 years until the traffic reports shut down.
I installed the 2017 SD card at the beginning of October and did a software and map upgrade to get the 2018 maps with a different menu layout and did it again this week on day 58 to get the latest 2019 maps with live traffic for another 3 years.
Always surprising how quick the maps go out of date.
Old Oct 23, 2023 | 02:48 PM
mmorgan's Avatar
c 220 d T
how did you update maps
