Non OEM illuminated star (easiest wiring yet)
Old Jan 7, 2019 | 05:23 PM
bngu1's Avatar
2019 E300
I bought the non OEM illuminated star from ebay and was able to install and have it lit with the parking lights. i have 2018 C300 with LED headlights. At the driver's side headlight plug, tap the red wire into the gray/yellow wire and ground the black wire to frame. The star will come on with parking lights.
Old Jan 21, 2019 | 12:36 AM
drkstvrr's Avatar
2016 C300 / W205
Does it stay on when you drive or is it off? I'm looking for one that only lights up when doors are locked / unlocked
Old Jan 21, 2019 | 12:37 AM
bngu1's Avatar
2019 E300
stays on when lights are on
Old Jan 28, 2019 | 11:32 PM
myachillesheel's Avatar
MB C250
hey you mind sending the link to that listing where you bought it?
Old Jan 29, 2019 | 01:06 PM
bngu1's Avatar
2019 E300
https://www.ebay.com/itm/Illuminated...53.m2749.l2649
Old Jan 30, 2019 | 06:00 PM
Shahw205's Avatar
'21, GLC 43 AMG, '20 Toyota Supra (Launch edition),'15 C300 (W205), 335xi (e92)
So it stays on when lights are on and the engine is off? If I unlock the car while I'm walking up to it, will the star come on when the day time running headlights come on?
Old Jan 30, 2019 | 06:02 PM
bngu1's Avatar
2019 E300
it does not come on with DRL, only with parking lights
Old Feb 20, 2019 | 02:28 PM
peter4884's Avatar
CLS 400
how did you figure out which wire to connect to?
I have a 2015 CLS and it does not have the colored wire you stated. It does have many other colored wires. Did you put a tester on it to determine volts? Peter.
Old Feb 20, 2019 | 07:04 PM
bngu1's Avatar
2019 E300
I did use a multimeter to test the wires
Old Feb 21, 2019 | 05:17 PM
fganter's Avatar
E350
To be clear - when the headlights come on (day or night), the star comes on, right?
I just came from a shop to get an LED star hooked up to my E350 with LED headlights. They said because it uses CANBus, they cannot connect to any of the headlight wires - would require different wiring, a switch, etc.
I'm wondering if I just went to the wrong shop.
Old Feb 21, 2019 | 05:28 PM
bngu1's Avatar
2019 E300
that is correct. regardless of day or night, if my parking lights are on the star is lit.
why not unplug one of the headlight plug and test thr wires yourself to see if one will work
Old Feb 21, 2019 | 05:36 PM
fganter's Avatar
E350
Right?! That's what I said!
They said they tested for current and because of the LED headlights and CANBus, it wasn't going to work.
I took it to the shop, because this isn't my thing. I wanted to pay someone to do what I thought would be pretty easy for a professional.
Old Feb 21, 2019 | 07:06 PM
bngu1's Avatar
2019 E300
Headlights are CANBus so maybe you can go back or try a different shop and ask them to find a parking wire or just have them tap into one of the wires for the ambient lights from inside the car and run it to the star. That is more work but its an alternative instead of having a switch to turn on the star
Old Mar 28, 2019 | 06:33 PM
Puma Elzufon's Avatar
2018 C300
Power wire gauge
Is the gray and yellow power wire a 16 or 18 gauge?
Old Mar 30, 2019 | 09:53 PM
allanyeung99's Avatar
2017 Mercedes C63s
I hooked mine to the fuse box, and it comes on whenever the car turns on. The only reason I did this was because I didn't have instructions and there was no damn way I was going to touch some expensive *** headlights. I just hooked the black wire to ground, then the red into the fuse box.
Old Mar 31, 2019 | 06:23 AM
fganter's Avatar
E350
What model car and which fuse?
Old Mar 31, 2019 | 06:56 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
I think this is the smartest approach yet. Just remember, if you have Distronic you cant use an illuminated star.
Old Mar 31, 2019 | 12:35 PM
2017 Mercedes C63s
Its a 2015 C400. I opened the hood, and my fuse box is on the driver side, and hooked it up to wherever there was a slot.
Old Mar 31, 2019 | 12:36 PM
2017 Mercedes C63s
I'd rather have the illuminated star be on all day rather than driving around with a broken headlight and pay like $1500+ for a new one.
Old Apr 2, 2019 | 03:00 AM
Dwarez's Avatar
C300 w205
Do you have problem?
[QUOTE=bngu1;7648315]I bought the non OEM illuminated star from ebay and was able to install and have it lit with the parking lights. i have 2018 C300 with LED headlights. At the driver's side headlight plug, tap the red wire into the gray/yellow wire and ground the black wire to frame. The star will come on with parking lights.
That have problem with system?
Old Apr 2, 2019 | 09:06 AM
bngu1's Avatar
2019 E300
Everything is working fine, no problems
[QUOTE=Dwarez;7721363]
Old Apr 21, 2019 | 09:18 PM
J. L. McLovin's Avatar
C300 W205
It's been a few months. How is the start holding up. I will be doing this install next month if you confirm all is still good!
Old Apr 22, 2019 | 12:19 PM
bngu1's Avatar
2019 E300
mine has been working flawlessly since the day i installed it
Old Apr 22, 2019 | 01:21 PM
2017 Mercedes C63s
Please note that different models might have different wirings.
Old Aug 20, 2019 | 08:46 PM
Esandoval87's Avatar
Mercedes-Benz C300
Spliced into Grey/Yellow
So I spliced the red wire to the grey/yellow wire from the driver's side headlight and the black cable to ground. But I can't get the star to light up.
