Retrofit = Halogent to Static LED Using Kabeldaviko Harness USA C300 2016
Old Feb 6, 2019 | 09:49 PM
cowners's Avatar
C300 2016
Question Retrofit = Halogent to Static LED Using Kabeldaviko Harness USA C300 2016
Hello Everyone, Hope you are all doing great!
I have been spectating the forum for a while and finally decided to register. I would like to say that this first post is going to be about how this retrofit worked just fine, but that is far from the truth.
After reading this post a while ago, i went ahead and purchased some Static Headlights on eBay, thinking the installation was basically a Plug N Play thing (or so the link said)... to my surprise, it was everything but that.
Some research later, i purchased the W205/253 cableharness from Halogen to LED stat. Code 631/632 and did my best installing the new harness while trying to decipher the instructions (picture attached, you will see what i mean).
Everything seemed to be working fine, but it did not take long for the errors to start piling up on the dash screen (more pictures attached).
My guess is that the car is still looking for the old Halogen headlights and because nothing is attached to those plugs, those errors are coming up. The manual did not mention anything about CODING though i think that might be the issue.
Another problem i ran into was the Right Side Headlamp turning on and off (video attached), this would sporadically stop and the light would remain on, but now it seems to be a permanent thing. I went ahead and switched both modules from one headlamp to the other, as well as trying the headlamp on the Left Side plug but the problem remains, so this makes me believe the Headlight itself is defective.
On a side note: The instructions mention and extra step for cars without Airmatik , it talks about a "brown insert" on the "X62/32 distributor". After locating said distributor, i realized that my car (Airmatikless) does not have any wires coming in or out from the "brown insert", it is basically an empty shell. So i was left with 2 extra wires i believe have nothing with my car nor the problem i am having.
Any help is highly appreciated.
Someone has to make this a little easier to understand. Lol
Old Feb 7, 2019 | 05:19 PM
realeric's Avatar
W205 C300, W212 E350, Q50
I don't have the answer you wanted but I guess you need to do either coding or installing load resistors.
Old Feb 7, 2019 | 10:24 PM
cowners's Avatar
C300 2016
I am thinking about leaving the resistors as my last option. Looking for something "cleaner" before i head down that path. I hope there is something
Thanks!
Old Feb 11, 2019 | 10:19 AM
Star4life's Avatar
2017 C43 AMG
you can pm me. I perform headlight retrofits for a lot of people.
this is not a plug and play scenario. from halogen to led static or ILS, it requires, new headlights, new modules, new wiring, level sensors on rear and front (for ils), new headlight switch and of course coding. its really not cheap to do this conversion. pm me and I can help you if interested in purchasing the services from me. this retrofit is not for beginners. if you don't have full knowledge of this system and coding, you will nto be able to plug and play at all.
resistors will not do anything for you. these headlights are controlled via can message.
Old Feb 11, 2019 | 08:22 PM
paulatl's Avatar
C300
Thanks!
I know it is doable, but it requires reprogramming. I know one vendor from China, and they are selling the reprogramming tool, but have no idea about the cost..
Old Feb 12, 2019 | 09:59 AM
cowners's Avatar
C300 2016
The new led headlights are already working, i used the https://www.kabeldaviko.de/product_i...e-631-632.html to connect them and they are functioning properly. I just keep getting the error messages because the car is still looking for the old connectors which are unplugged.
Old Feb 12, 2019 | 10:00 AM
cowners's Avatar
C300 2016
do you know where i can find this tool?
thanks
Old Feb 12, 2019 | 10:30 AM
Star4life's Avatar
2017 C43 AMG
thanks
tools can be found on ebay or ali express but then the setup of all software and such is very time consuming. if you plan to code a lot and do more than just your headlights id say go for it. after all is said and done you'll spend around $1000 for a clone system. NOT oem.
if you only need to do this once, i recommend paying for the service. you will save a ton of time and hassle.
Old Mar 18, 2019 | 08:21 PM
golfy1875's Avatar
GLC 300
https://www.ebay.com/itm/MB-Star-SD-...0c16%7Ciid%3A1
Can you please show me wiring diagram for 631-632
Thank you
Old Mar 18, 2019 | 10:05 PM
Trappers101's Avatar
2016 C300 4matic
Sorry to hear about all this.
Can you undo everything that you did?
I bought mine and they are true Plug and Play, no error codes no nothing.
Remove the old factory Halogens and Plug in the new LEDS...turn the adjusting screws to level out the light pattern and done!
W205 2016 C300 4Matic
Old Mar 20, 2019 | 11:21 AM
cowners's Avatar
C300 2016
Where did you buy them?
Old Oct 22, 2020 | 11:39 PM
Tyler Hall's Avatar
2015 c300 Sport
Ever figure out a solution using this harness?
