Aftermarket 9.33" Android Screen Install Guide + Photos
Old 02-16-2019, 10:50 AM
Rami Mohsen's Avatar
c180
@ShakyTom This looks nice , could you send me the new software link ? maybe if I update my screen I can access the sound settings
Old 02-16-2019, 12:25 PM
ShakyTom's Avatar
C43 AMG Coupe
Done a bit more work with a custom launcher to make everything as easy as possible for the car.
Old 02-16-2019, 04:44 PM
RUNSGR8's Avatar
2017 C300 Coupe - Polar White/Saddle Brown MBTex
Originally Posted by ShakyTom
RUNSGR8, I've installed Simple Control but still have the stock buttons available in the bottom-left corner which often get in the way when using some apps; have you found a way to completely stop them from appearing?
I'm guessing you still use BCLauncher? Pull up the app switcher view (the square icon in SimpleControl) and swipe away BCLauncher from the list of apps. That's where the stock buttons in the bottom-left are coming from.
Old 02-16-2019, 04:46 PM
RUNSGR8's Avatar
Originally Posted by Rami Mohsen
How did you get Apple CarPlay? Did you use a certain adapter box?
Also, can you please go to Android Settings and post a picture of the screen with all the versions? Should be in the "About" section. I wonder if your tablet has a new update that disabled Sound Enhancement.... If so, I'll hold off on updating mine.
Old 02-16-2019, 05:10 PM
c180
i used the CarPlay adapter from the same seller. It opens CarPlay automatically when I connect my phone. A friend got the screen and the adapter from 2 different sellers and he had to open the CarPlay app manually every time he connect the phone.
Here is my about page
Old 02-16-2019, 05:13 PM
RUNSGR8's Avatar
Gotcha. How's the general UI performance with the CarPlay box? I'm sure you've noticed that the Google Maps app from the tablet is pretty jittery and slow.
I'll check my version later today and see if your versioning differs from mine.
Old 02-16-2019, 05:21 PM
  #32
c180
carplay box general performance is pretty fast. Better than the tablet because all the processing is done on the phone itself. Didn’t get to use google maps a lot , I’ve only installed the screen last night but yes. Not so fast and I’m sure it will get worse
installed my gps tracking and automation apps as well and will test it and see
Old 02-17-2019, 01:07 PM
  #33
c180
many luck with the firmware ? Is mine the newer one ?
Old 02-17-2019, 06:38 PM
  #34
fgarcor's Avatar
Mercedes w205
Mine is the same one and I just bought it one month ago.
Old 02-17-2019, 06:41 PM
  #35
c180
no sound enhancement settings as well ?
Old 02-17-2019, 06:43 PM
  #36
fgarcor's Avatar
Mercedes w205
I didn't have time to check it. I will report it later.
Old 02-17-2019, 07:47 PM
  #37
ShakyTom's Avatar
C43 AMG Coupe
Does anyone else have an issue where the clock is completely wrong on startup? If so, have you found any way to solve it?
Got my new home screen all setup now, seems to run a lot better with this launcher than it did with stock one and everything is super easy to access
Old 02-17-2019, 08:57 PM
  #38
RUNSGR8's Avatar
Nope, you've got the same one as me.
Yeah I have that issue as well. It's kind of annoying, but not a huge deal since I have mine to grab the time from GPS. That way, even if I don't have a hotspot available for any reason, I'll still have accurate time.
Old 02-17-2019, 08:59 PM
  #39
RUNSGR8's Avatar
Maybe try doing a full System Reset? Not sure why you wouldn't have those settings.
Old 02-17-2019, 09:25 PM
  #40
ShakyTom's Avatar
C43 AMG Coupe
I wonder if the new firmware fixes the clock then
Old 02-17-2019, 09:26 PM
  #41
RUNSGR8's Avatar
I probably won't get around to flashing the new firmware till next week.
I'd recommend just getting rid of the clock altogether on your homescreen if it bothers you. We still have a clock in the center console + the center screen in the instrument cluster.
Old 02-18-2019, 03:31 AM
  #42
c180
can you PM me a link to the firmware. I can flash it today
Old 02-18-2019, 05:01 AM
  #43
c180
did a full system restore and now I can access the sound settings. It’s so strange but it worked. Now it’s sounds perfect exactly like the car stock sound
I have to reinstall the apps now but it’s all better
Old 02-18-2019, 08:58 AM
  #44
RUNSGR8's Avatar
Just PMed you. Let us know how it goes!
Old 02-19-2019, 07:36 AM
  #45
c180
did the update , it went smooth , some new audio settings for the EQ , no much difference in layout but it feels a lot more faster.
It will erase your apps and settings and reset your tablet
went from version 1 to version 3
wip7 (03-15-2019)
Old 02-19-2019, 05:11 PM
  #46
ShakyTom's Avatar
C43 AMG Coupe
Will export my current launcher setup and then perform the upgrade as well at some point then
Any downsides to the newer version yet?
Old 02-19-2019, 05:21 PM
  #47
c180
nothing so far , they even changed the android buttons menu and it's now a lot better
I wish there is a way to remap the car buttons , I want to map my steering wheel sound command button to launch Alexa on the tablet
I saw some remapping options in the CarPlay app but it's a bit confusing
Old 02-19-2019, 05:41 PM
  #48
ShakyTom's Avatar
C43 AMG Coupe
That's why I setup a custom launcher with huge buttons for everything... It can be incredibly difficult to use a touch screen when driving.
Old 02-19-2019, 06:26 PM
  #49
RUNSGR8's Avatar
Awesome, thanks for being our guinea pig, Rami. So the performance is much improved with the new update? Less lag and stuttering?
Old 02-20-2019, 04:22 AM
  #50
c180
Hahaha , You are welcome @RUNSGR8 , I didn't get to test it a lot but it feels snappier , one thing I didn't try and you might be able to help with , after the update I installed a couple of apps , then I checked again for an update and it said a new version is available ( while the USB drive still connected ) not sure if this update is done using 2 steps ( highly doubt it ) or it's just stupid and don't really compare the builds and just say they sound a new version just because it's on the USB , if you can update 2 times in a row and compare it would be great
Quick Reply: Aftermarket 9.33" Android Screen Install Guide + Photos
