Android 10.25" display software update V35 (2019/01/04)
10.25 display android 8.1
i need help, i just update the the new version of the android 10.25 display in my mercedes and now i can't change the boot logo bc the software system settings password change someone know that new password please i will appreciate
software system passwords
#33
yes i did but the old password 8888 doesn't work they change it but they don't wanna give to the customer bc they say it is having problem when u change something, but i was wondering if someone has the new password
#34
23 plate A class 180 amg prem plus night edition mountain grey
Make sure the file u copy from this download to memory card is named bootanimation.zip. Copy this file to the internal memory of the screen and save it in the root folder ..Then go into settings look for your firmware click that and enter 12345678 then press the top box and update .. will be all correct again then
#35
Found out the error why sound is not working: I have activated the "Radio" app in the secret menu. And this app causes the sound issues. So after deactivating it works very well.
The new password for the secret menu is 1812 instead of 8888
#36
Thank you
djshaz99 (01-06-2022)
#37
If anyone is needing the V35 update, you can find it here for 7 days from 19-02-2019:
https://fil.email/uPZ3O0UZ
https://transferxl.com/08v8Bs4Nkx7Pc
https://www.plustransfer.com/downloa...3b3b0acb47f0c6
https://megaupload.nz/ZbMd00ufb3/10....5_20190104_zip
What is included (10.25 - 1280x480 - dated 2019-01-04):
- UI upgrade: 3562.bin + 3562.upd
- MCU upgrade: ts24x.bin
- CAN upgrade: can_app.bin
- Boot animation update: bootanimation.zip
- Installation guide: HOW TO.jpg
Update at your own risk and enjoy...
Thanks.
#38
Here are the "complete" V41 update including UI, MCU and CAN:
https://transfernow.net/54ap8712ina2
As always: update at your own risk.
Happy updating....
Happy updating....
#39
Originally Posted by bngu1
can i please have v41. the upload file was expired. thank you..
https://transfernow.net/81krs1m4olcl.
regarding the V41 UI.
They say that it is still full of bugs and I think we should wait for these to be crushed.
Furthermore, personally, I like the V36 UI much better.
(if you need the password for the submenu of V41, it is 1812)
https://l.facebook.com/l.php?u=https...Ki-z7z83HbC1II
When installing V36 it might switch to chinese language, but this can be changed in the submenu (code 8888)
Although some guidance could be necessary
#40
W117 cla
Hi.
I could use some help.
Today I have installed an 10,25 android system in a cla w117 model 2014.
The car has ntg 4.5.
The problem that I am facing is that command is not visible, audio and all other functions work perfectly. LVDS cable is connected as well
Any suggestions?
Any suggestions?
#41
Hi.
Any suggestions?
Any suggestions?
Play with the numbers until 13
#42
[QUOTE=shan16;7811204]Before you pull a part to check the harness. Check the screen resolution on android factory settings
Thanks for the reply! My screen resolution goes until 10, but nothing happens..My menu is different. Also a I haven't got the NTG selection.
#43
[QUOTE=E200GR;7811656]Ask your supplier to supply with factory settings reset bin file to reset and then you should see the main factory settings after you entered the pin
#45
#47
#49
I don't know how you getting in to the hidden menu as I don't have the same version as you but can you fellow below video and see if you can set it up? If not go to setting and do full reset and see if that brings up the menu and if you don't mind can you send me your software version pictures
#50
