Android 10.25" display software update V35 (2019/01/04)
#51
#53
Sorry I forgot to add the link https://www.youtube.com/watch?v=0-Sxu9KzDwQ
Btw your missing the can version meaning you mite have not plugged something at the back properly
You need to pull whole think out and plug everything again
#54
I think iam lost. You haven't got this installed on your car?? You said monitor isn't installed? Which one are we talking about
#55
#56
I can't help without you installing the screen and connecting all the harness may be try one more try and connect the OEM harness to the screen harness blue plug
#57
#58
dkbkl (08-03-2019)
#59
#60
Ok long story short I have failed miserably. loaded the two initial files onto an SD card and the screeen just booted as normal even after resetting it. Even tried to update through the USB connection. Might it that the update is not compatible with the current software running on the screeen? Help pls (I have included a picture of my current software version)
#61
#63
#64
Ah thanks for that shan16. Any ideas on how I can over write the software currently on it as I have tried the sd card followed by reset but no joy
#65
You need to ask your seller if you can flash new firmware into it I doubt you can because there wont make any money but offer them some cash for the firmware there might consider
#66
Hi,
Does anyone know how to overwrite the outdated carplay app(which is not compatible with my dongle firmware ) with the newest autokit.apk ?
now im not able to use carplay from the icon because its starting carplay instead of autokit.apk
#67
No more next/previous track command after update.
Hello,
I own a 10.25 screen.
I did upgrade to v35 few months ago.
Everything went fine except that i dont have the next track command anymore. With the previous version, i could jump to the next track (it worked for any apps, YouTube, radio app, any music or video player) by pushing the command wheel to the right (and jump to previous track by pushing the wheel to the left).
Since the update, when i push to wheel to the right, it doesn't jump to next track. The result by pushing the wheel to right is similar than when i turn the wheel.
So i have to scroll the notification down or open the app for jump to the next track. It is a little bit unsecure when you are driving...
I guess it is an issue with the new version of the CAN...
Does anyelse have this issue? How do you solve that?
Or does anybody have the v33 or older version, so I can test to upgrade an oldest version of the can ?
Thanks in advance.
Thanks in advance.
#68
Here are the "complete" V41 update including UI, MCU and CAN:
https://transfernow.net/54ap8712ina2
As always: update at your own risk.
Happy updating....
Happy updating....
#69
Hello,
Thanks in advance.
Thanks in advance.
The next version I have is V35
#70
V41
https://transfernow.net/161nf1g93eaq
And the passwords:
Boot logo: 5678
MCU update: 0
Secret menu: 1812
(find the machine settings - version information - there is a small icon in the upper right corner)
And the passwords:
Boot logo: 5678
MCU update: 0
Secret menu: 1812
#71
#72
Do you have the related MCU?
I guess the culprit is the mcu, not the rom.
Do you have the same issue as i described since you upgraded to v35 or 37 ?
Cheers.
#73
Hello,
Thanks in advance.
Thanks in advance.
#74
#75
Thanks bro. Successfully updated v41. Do you have the boot animation file as well? Thanks bro
