C400 CV Axles
For those who have had them replaced under warranty, did they replace them with the same part number? Was there just a bad batch/isolated issue at the supplier? I noticed that the C450 also uses the same PN and I don't recall seeing threads with these issues.
If they will not good-will them, I was also thinking of picking up a used axle for $150 vs. $850 new, that doesn't seem like a bad idea if it was a batch issue (as long as this axle isn't from that batch).
Let me know your thoughts! I absolutely love the car in every way so far
I do have this grumbling sounds when im drivng in a parking lot full of bumpy ice/snow...the dealer said the rear axel damps need replacing so I am waiting for warranty on that as well..
but the fronts are a common issue with all the c400, essentially the initial factory ones are garbage...
The section lower down on the page that says "replaces:" seems to have the older part#s
I can hear it sometimes while turning left or right.
I'm wondering how did you fix yours.
Was it on both sides? Did you buy a used or new part? Was it oem or aftermarket?
I found some used ones for 180 oem but I don't know if it will be the same bad batch or not.
Also found aftermarket ones for 450.
Any feedback would be much appreciated.
Thanks.
Thanks.
I had mine replaced under warranty, I don't know if it was same part number but the mechanic at MB said the original CVs that came with the car was very poorly designed so they all have that issue..the new ones they replace it with is much better..hope that helps
My axle also did this, but only one. MB replaced them both for me no charge. They said the sound came from a bad design and is not actually failing, but they replace them anyways and prefer to replace them in pairs. After they are replaced, you get a new 2 year warranty on them.
Mercedes Drive Shaft CV Joint Kit (Front outer) $172.99
https://www.fcpeuro.com/products/mer...gkn-2053309910
