Need part number for Gray Plastic Mercedes Wiring Connector Plug Pin Lock Thingy
Old Mar 30, 2019 | 02:53 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Thumbs up Need part number for Gray Plastic Mercedes Wiring Connector Plug Pin Lock *SOLVED!*
I broke the gray locking pin while disconnecting the passenger side front bumper harness connector.
Anyone know if it has a part number or is sold separately?? I've also seen them on headlight connectors.
Broken pin
You can see it @ 4:15 in this video
Old Mar 31, 2019 | 12:38 PM
benzdude's Avatar
Top Answer: 1
Help
Old Mar 31, 2019 | 01:03 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Any clue what that wire is at 4:15?
Old Mar 31, 2019 | 01:11 PM
benzdude's Avatar
Top Answer: 1
its in the front bumper on the right inner fender. My car has parking sensors in the bumper I guess. I've added a zip tie for now. Thanks.
Old Mar 31, 2019 | 01:15 PM
benzdude's Avatar
Top Answer: 1
It appears most MB cars have it. check video @ 1:20
Maybe I can find a salvage harness?
Old Mar 31, 2019 | 10:27 PM
Trappers101's Avatar
2016 C300 4matic
When I changed out my factory illuminated star for an aftermarket one, it did NOT come with a plug end, just bare wire ends. I didn't want to cut the original factory plug just in case I wanted to change it back so I had to find an original factory plug end. Sounds like a simple find right, I mean after all there are countless wire connectors used in every German car made over the last unpteen years. After searching the web I seen a few that 'might' be the right part but didn't show a clear photo of the inside. Rather than order something that might work I took the original star with the factory plug end to a couple of repair shops that specialise in Foreign cars. On my 3rd stop I found a shop that works mostly on BMW's. I showed the guy what I needed and he fumbled around in a box full of wiring harnesses and pulled out one that was an exact match! Cost was $25.00, which was probably twice the actual cost but hey he was holding the part that I needed in his hand so I bought it.
Hope that helps ya' Benzdude!
Old Mar 31, 2019 | 11:16 PM
benzdude's Avatar
Top Answer: 1
I think I found it. Thanks!
I googled and found a picture. There is my gray pin!!! $10
Old Apr 6, 2019 | 02:12 PM
benzdude's Avatar
Top Answer: 1
