2019 Facelift C Class w205 body kit fits pre-facelift models(2015-2018)?
I searched information regarding this subject but i could not find anything.
I own a C Class w205 (2015) 220d sedan and love the new look on the facelift model from 2018-2019. I would like to know if the OEM body kit of the new facelift model can be fitted to the pre-facelift models.
The front bumper is much nicer (E Class style) while the rear bumper is very similar to the previous model.
Are there any aftermarket manufacturers for bumpers and skirts for the facelift model?
I'd be interested as well, since I would need to replace my slightly damaged front bumper anyway. I still can't decide which one I like better however. I definitely prefer the diamond grille though.
Did my front-end conversion earlier this month.
Just some minor caveats to note:
1. Wire harness for Collision Assist sensors (the ones previously on the left/right inlets) needs to be extended for placement on facelifted bumper.
2. Custom bracket (installed behind the bumper) needed to secure Collision Assist electronic module on new bumper.
I went through a specialist bodyshop who had access to the MB spare parts database because it is near impossible for a layman to collect all the correct part numbers off the web.
Also, some parts differ according to your configuration options - i.e. bumper with/without 360-degree camera, so you may have to choose from 4 or 5 possible part numbers for a single part.
This looks great! Good job there mate 👍🏽
I've bought a OEM facelift front end. In the process of installing.
Regarding the fitting issues you described;
Do you know what is involved in extendinh the parking sensors? I see that they are just 2 wire plugs. Did you simply cut and solder extra wire in between?
And also did your original factory undertray line up and fit okay?
In the process of the front end conversation. Did you go through with yours?
Yes, the factory inner tray from the old bumper can be swapped over and attached to the new bumper.
Thanks for the prompt reply
Good to know the original undertray will fit.
Also regarding
"2. Custom bracket (installed behind the bumper) needed to secure Collision Assist electronic module on new bumper."
Are you referring to the Distronic radar behind the Mercedes star? Or is there a seperate parking sensor module for the front that I assume can be tucked away in the new bumper somewhere safe.
Cheers
Also regarding
Cheers
I’m curious about this also! Here’s an update on my comment at the bottom of the thread… The top photo shows the old bumper with the radar and brackets and the bottom is the new bumper and where it should be located… Not sure how to progress from here.
See in this post:
https://mbworld.org/forums/c-class-w...ml#post8554598
See in this post:
