NEW Style Sequential Blink LED Dynamic Turn Signal Light For Mercedes Benz with BLUE
Old May 21, 2019 | 02:28 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by MercedesN8
Which one was the one that gave you trouble when you ordered?
One of the iSincer signals had a loose frosted overlay inside.
It wasn't aligned properly and you could see the leds behind it. I just gave it a quick slap and that fixed the issue.
Old May 21, 2019 | 03:29 PM
C300AWD's Avatar
C300 4matic
Video of the dynamic turn signals in use? Do the lights flow smoothly?
Your posts are always making me spending more money...
Old May 21, 2019 | 04:35 PM
MercedesN8's Avatar
15' C300 4Matic
So which seller are these from? The seller that sent them the fastest?
Old May 21, 2019 | 07:44 PM
benzdude's Avatar
Top Answer: 1
iSincer
Old May 21, 2019 | 07:46 PM
benzdude's Avatar
Top Answer: 1
Click on the link in post #1
Old May 23, 2019 | 04:57 PM
MercedesN8's Avatar
15' C300 4Matic
I pulled the trigger can't wait!! Your a bad influence Benzdude lol Thanks for posting all you do makes it easier for us to follow suite!
Old May 24, 2019 | 01:11 PM
  #32
benzdude's Avatar
Top Answer: 1
I just got my second order from another seller, they are both the same product and the second order has the very same issue as the first order (on same side).
I tapped it a couple of times to fix it.
Old May 24, 2019 | 01:23 PM
  #33
benzdude's Avatar
Top Answer: 1
Here you go. Smooth as butter.
UNLOCK (with blue)
LOCK
Old May 24, 2019 | 04:46 PM
  #34
benzdude's Avatar
Top Answer: 1
All done. I simply used a glue gun on the green (blue light) wire.
(I didn't realize that the drivers side mirror is bigger than the passenger side.)
Carbon fiber covers installed.
Old May 24, 2019 | 05:05 PM
  #35
benzdude's Avatar
Top Answer: 1
I have an extra pair of turn signal lights FOR SALE (brand new) $55. *** SOLD ***
Old May 24, 2019 | 07:53 PM
  #36
benzdude's Avatar
Top Answer: 1
HOW TO REMOVE OEM TURN SIGNAL WITHOUT BREAKING ANYTHING.
  1. After removing the two screws, unclip the bottom corner of the turn signal and lift it up about an inch.
  2. Move the end to edge of the cover.
  3. Pull back gently on the cover to allow the end of the turn signal to slide out.
  4. Install in reverse.
Old May 24, 2019 | 08:16 PM
  #37
MichaelCS's Avatar
2016 C300 Sport
You sir are a bad influence. My Mercedes bookmark folder is starting to grow with all the things that I want to add. First black chrome diamond front grill, then chrome delete, then black mirror covers to complete the night package look. Then vorsteiner vff 107 in Black. Then a C63 rear diffuser. That should about cover exterior. Not like there's anything left to cover LOL
Old May 25, 2019 | 10:14 PM
  #38
obz's Avatar
obz
Mercedes-Benz W463
Just got mine installed too. I didn't have the issue with them being misaligned. Looked good out of the box. Installed in about 5 minutes. Easy peasy!
Old May 26, 2019 | 12:43 AM
  #39
Ianinaurora's Avatar
Glc43
Connect ground wire
Hi. To what did you connect the green ground wire to?
Old May 26, 2019 | 12:52 AM
  #40
benzdude's Avatar
Top Answer: 1
Green wire needs 12 volt, not ground.
Contact to puddle light harness 12 volt.
Old May 26, 2019 | 08:38 AM
  #41
MichaelCS's Avatar
2016 C300 Sport
Did you get the carbon fibre slide-on covers or the entire housing replacement? I'm looking at adding these on mine after I put on night package finish (chrome delete, powder coating the stock rims in the same style, adding black mirror covers).
Old May 26, 2019 | 09:17 AM
  #42
Glc43
Thank you Benzdude for clarification. Will give that a try later this morning.
When I take the LED harness out I see 4 terminal wires. Which do I connect to so that I don’t create a short?
Old May 26, 2019 | 10:58 PM
  #43
benzdude's Avatar
Top Answer: 1
$16 stick-on carbon fiber (plastic) covers
Old May 26, 2019 | 11:07 PM
  #44
benzdude's Avatar
Top Answer: 1
4 terminal wires???
Strip the end of the green wire, fold the bare wire in two and stick it in the blue wire side of this harness. Add some hot glue to keep it in place. That's all.
Old May 27, 2019 | 11:29 AM
  #45
Glc43
Thank you
Thank you very much!
Once again. Thank you very much!
Old May 28, 2019 | 11:37 AM
  #46
benzdude's Avatar
Top Answer: 1
I think i will order some actual carbon fiber (plastic) covers.
The stick on ones don't cover the back of the turn signal and the fit isn't that solid.
Old Jun 13, 2019 | 02:37 AM
  #47
shivinate's Avatar
C400
Left Turn Signal Malfunctioning
Hey guys, I wired both the same way, but check out the issue I’m having with my left turn signal when locking the car along with indicating a left turn as shown in the videos (imgur - https://imgur.com/a/cFHxXvi [won’t let me upload videos through phone]) Is there any reason for this that I can fix? Or I need to contact the manufacturer.
Also noticed that both of my car key remotes all of a sudden are having their keystrokes go by unregistered from the car at times (will occasionally not recognize I clicked lock unlock etc) seemingly the same time I had these done, is there a correlation (is housing for remote’s IR in the driver’s side mirror?)
Thanks for any input :
Old Jun 13, 2019 | 12:34 PM
  #48
benzdude's Avatar
Top Answer: 1
I decided to order completely new "carbon fiber" covers for a cleaner black look.
The seller included a set of OEM look led turn signals, but I will swap them with the black (blue) dynamic ones.
Old Jun 13, 2019 | 03:08 PM
  #49
MercedesN8's Avatar
15' C300 4Matic
Do they work? Mine did that on the driver side but wasn't plugged in all the way and it actually bent the little pins in the turn signal had to bend them back out. Then when I turned off and restarted it went away. Not sure about the remotes. My drivers side gave me hell but I finally got it working the passenger side was a breeze! They look and work great no more issues
Old Jun 13, 2019 | 03:10 PM
  #50
MercedesN8's Avatar
15' C300 4Matic
OOOHHH Sexy Benzdude!! How much and where did you order them?
