W205 Retrofit facelift 2019 steering wheel
Old 06-26-2019, 01:01 AM
camelfarmer06's Avatar
2016 W205
Exclamation W205 Retrofit facelift 2019 steering wheel
Hi,
Does anyone know any information on wether it is possible to retrofit a 2019 C Class steering wheel to a pre-facelift model?
I cannot find any posts on this, my research has lead me to a video on Youtube which show is sucesfully being done:
If you have any information at all, please share.
Old 06-26-2019, 08:46 AM
CJG
CJG's Avatar
2016 C300 4MATIC
I doubt many (or any) of the functions would work. It operates completely differently including small touch pads. I'm sure there's different software required at a minimum.
Old 06-30-2019, 05:37 PM
Andy74's Avatar
W205 2015
I swapped mine you need a module to make it function.
The following 3 users liked this post by Andy74:
jevsays (08-04-2019), mjs1190 (07-01-2019), ronac (06-30-2019)
Old 07-05-2019, 01:31 AM
mxsolid's Avatar
C43 AMG
distronic keys on steering wheel
are you able to use the distronic and limiter keys on the steering wheel? or still using ist the "old" way?
Old 07-05-2019, 06:46 AM
Andy74's Avatar
W205 2015
Old way
Old 08-09-2019, 09:54 AM
Sakif Zaman's Avatar
C300 Sport 2016
Whats a module? Also if i were to purchase this steering wheel, as well as the module, would I be able to plug and play and have it working perfectly, or would I have to code/program anything including the buttons?
Old 08-09-2019, 10:09 AM
Andy74's Avatar
W205 2015
I bought it with its module no programming required. The only thing is that the cruise control buttons do not function. You can use your existing cruise control stick.
Old 08-09-2019, 10:12 AM
C300 Sport 2016
So all pins and stuff fit perfectly? Also where can I purchase that same setup with the module?
Old 08-09-2019, 10:23 AM
Andy74's Avatar
W205 2015
http://www.eurohausmotor.com/
Old 08-09-2019, 03:44 PM
TorbenK's Avatar
C220D W205 Estate
I thought you were to change the column also?
Old 08-09-2019, 04:23 PM
Andy74's Avatar
W205 2015
No not at all. Only steering wheel plug and play.
Old 08-13-2019, 06:10 PM
pussgalore's Avatar
na
Hey, do you have a part number for the new steering wheel? Thanks
Old 08-13-2019, 06:19 PM
Andy74's Avatar
W205 2015
I frankly do not have a part number as I purchased as a whole including its airbag.
Old 08-13-2019, 07:23 PM
pussgalore's Avatar
na
Oh ok. I hadn't thought about the airbag. Sounds too advanced/complicated for me to do this
Old 10-07-2019, 01:11 AM
AkibaDeep's Avatar
2015 C300
So any link to the actual product? I can't find it on the http://www.eurohausmotor.com website
Old 10-07-2019, 08:16 AM
Andy74's Avatar
W205 2015
They are based in Thailand Contact Sam on watsapp +6689-227-7756 I dealt with
him. They don't have an online shop.
Old 11-05-2019, 01:18 AM
C250d-4M's Avatar
C250d 4-Matic (S205)
The airbag is also plug & play?
So you do not have to coding / program anything?
Old 11-05-2019, 04:36 AM
Andy74's Avatar
W205 2015
Correct
Old 11-05-2019, 05:51 AM
C250d-4M's Avatar
Correct
Sure you do not have coding anything?
Because, I have read that “After installation AirBag coding is required of ORC222 module (in W222/C217 cars from 2018 MY only one airbag stage is used instead of two). Coding can be performed with VEDIAMO software.“
Old 11-05-2019, 06:56 AM
Andy74's Avatar
W205 2015
They have done all the coding themselves, installed the module and shipped it to me. i just installed it.
Old 04-13-2020, 08:03 PM
Sadam Taha's Avatar
W205 2016
Need help how to install by steps please
I want to ask the steps and if there is any think to do like new software or anythingmy car 205 2016 and what is should to do to tell the mechanic how to install please this the first thing
Second: can i install touchpad because my car came without it ?? Please replay thanks alot
Old 04-14-2020, 08:52 AM
Andy74's Avatar
W205 2015
You need a module so that the car will understand the commands coming from a 2019 steering wheel. I purchased mine with its module and airbag. All buttons works except cruise control. The existing cruise control shift remains active.
Sadam Taha (04-15-2020)
Old 04-14-2020, 09:01 AM
Andy74's Avatar
W205 2015
Originally Posted by chris is banned
He ask about the 2016 wheel. Not the 2018 wheel.
He mentioned: "my car 205 2016".
Old 04-14-2020, 09:25 AM
Andy74's Avatar
W205 2015
That is corect. My mistake. There is wheels now where ALL buttons work inc cruise. Plug n play.
Yes surely plug and play if the buyer has already programed the 2019 steering wheel or included a module in it. Mine was shipped with its module. I never used cruise control so the fact that the cruise control buttons dont work it did not bother me. Note that existing cruise control handler is still working.
Old 04-14-2020, 09:29 AM
Andy74's Avatar
W205 2015
No! There is wheels now where ALL buttons work inc cruise with no converter. Plug n play. Contact plate is made for the car directly.
Oh great no converter? Where to buy? Any links.
Quick Reply: W205 Retrofit facelift 2019 steering wheel
