Shift Problem Solution ( w205 No More Jerky )
Old Aug 22, 2019 | 02:39 AM
Khanh Tran's Avatar
C300
Anyone who has shift jerked into gear 1-2 or 2-3 can try this Diverter valve DV+ T9358. It take 20 minutes to install and very easy DIY job.
I tried it for 6 months and there is no more jerky, run like an CVT transmisson
GFB’s DV+ solution is more responsive, less expensive, easier to install, and doesn’t cause compressor surge/ turbo flutter
It provides an faster boost recovery on gearshift and during throttle modulation
Improved boost holding ability
You can also buy it on ebay , make sure the model is T9358 and the real one.
Link for more details : https://gfb.com.au/products/blow-off...-volvo-detail/
Old Aug 28, 2019 | 11:56 AM
MercedesN8's Avatar
15' C300 4Matic
So will this work on a 2015 C300? They don't have years just says C300 on their site? What year and model do you have?
Old Aug 28, 2019 | 11:40 PM
Khanh Tran's Avatar
C300
T9358 model. My car is 2015 C300 4 matic. w205 i4 Turbo. I bought it here from ebay.
Old Aug 29, 2019 | 02:05 AM
Doa's Avatar
Doa
W205
looks more like spam then an actual user report...
Old Aug 29, 2019 | 10:29 AM
Khanh Tran's Avatar
C300
Anyway, thank you for your comment . Before you type ( Hand ) check your knowledge first ( Brain ).
In an effort to help you open your mind. I just give you some of the information
You can search by google : BLOW OFF/DIVERTER VALVES
Youtube Research :
Make sure your car is Turbo Engine
Khanh Tran's Avatar
C300
Old Aug 29, 2019 | 11:13 AM
MercedesN8's Avatar
15' C300 4Matic
Cool thanks for the info, I researched and I ordered one, so hopefully it will help. I have the same car as you a 2105 C300 4matic.
Old Aug 29, 2019 | 02:23 PM
Pope_RW's Avatar
C300
What W205 has a 1.8L?
Additionally a BOV is turbo related, not transmission.
Old Aug 29, 2019 | 05:42 PM
allanyeung99's Avatar
2017 Mercedes C63s
I'm confused on how shifting is affected by the boost of turbos and not your transmission. I've had this problem and many people say it needs an software update for the trans.
Old Aug 29, 2019 | 11:21 PM
Khanh Tran's Avatar
C300
I did and it work. That all I can tell you for 139 USD. My MB Dealer did the software update, but nothing better so far.
Check the Video above and you can understand.
Old Aug 29, 2019 | 11:24 PM
Khanh Tran's Avatar
C300
The video I post is the same ideal as C300 W204 and W205 Turbo Charge.
You follow his instruction and do the same way on W205.
I did it. It makes my car transmission work smoother
Old Aug 29, 2019 | 11:43 PM
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
Old Aug 30, 2019 | 06:53 AM
Pope_RW's Avatar
C300
I call Bravo Sierra on the BOV doing anything, here we see the actual resolution of the shift issue "software update", a BOV will not change how a transmission shifts.
Search the forms here, there are numerous references to after-market atmospheric BOV's and other than adding the "pshhhhh" sound at vent, do not improve performance.
Old Aug 30, 2019 | 08:05 AM
Doa's Avatar
Doa
W205
so the atmo V6 3.0 is the same as the i4 2.0 turbo engine voor this part?
Old Aug 30, 2019 | 11:44 PM
Khanh Tran's Avatar
C300
Believe or not believe is up to you. Even if you put some bad quality gasoline can cause an engine damage. Everything need to have and experience in life. I did it and it worked on my car and my friend car. That's it. I have the right to share my good opinion.
Did you give your car a try yet ?
Old Aug 30, 2019 | 11:45 PM
Khanh Tran's Avatar
C300
Turbo Charge Engine Only
Old Aug 30, 2019 | 11:47 PM
Khanh Tran's Avatar
C300
Did you do it yet ?
Old Aug 31, 2019 | 03:36 AM
Doa's Avatar
Doa
W205
Did you do it yet ?
Then I already have no clue why you come up with the w204 c300 as this was not turbo charged
Old Sep 1, 2019 | 12:05 AM
Khanh Tran's Avatar
C300
as I said : Turbo charge only. The W204 - 1.8 Turbo Charge Version. The V6 is not Turbo Charge. Can you search on google ?
Old Sep 1, 2019 | 12:54 AM
Back to reality though, I took my W205 in to the dealer last week and they applied software update campaign 2019030013 for the powertrain. Since I got the car back, all upshifts and downshifts are now smooth as butter.
I'm just not sure if it's smoother now because of the software update or because the transmission "learning" was reset as a result of the update. I guess if it was the latter, the shifts will gradually get rougher again.
As an aside, I installed a turbo BOV on my last car (Fiat 500 Abarth) and understand the mechanics behind it. At best the BOV will allow the turbo to recover faster after spooling, but mostly it just vents any remaining turbo boost/pressure to the atmosphere instead of recycling it back into the combustion cycle as the manufacturer intended. There is just no logical way it could affect a component as far downstream as the transmission.
Old Sep 1, 2019 | 03:06 PM
Doa's Avatar
Doa
W205
So I reply to your previous message "The video I post is the same ideal as C300 W204 and W205 Turbo Charge."
The 204 c300 was a v6 atmo.​​​​
