Repair stuck/rattling W205 headrests
With a pick tool I managed to extract the leather flap end which is pressed into the base between the bars at the front underside.
Front edge of base flap.
Peel back. Repeat for corner and side folds which are similarly pressed into the internal frame.
Pop out side button, use flat tool.
Slide the frame out of the cushion
Remove two Torx screws, and split the case from the bottom, hinging on the top, there are two click fit catches in the middle down a recess on the other side, you might have to prise these a little.
Bingo! Two loose springs and slides fell out, plus a few tiny bits of sheared plastic.
These it turns out are what retained the slides pressed against the springs under the bar. Not sure of its purpose, could be some kind of one use anti whiplash brake on the bars.
The plastic retaining lugs for this spring are also almost fully broken off, allowing the spring to rise up.
With the spring removed you can see the lug hooks hanging off.
The small broken pieces came from here, which would retain the two slide pieces against spring pressure held in the area above against the round protrusion. The other end of the slide was also retained by even smaller pin size pieces of plastic moulded on that protrusion which had broken off.
These slide devices seem to rub against the bars as you move the headrest fore and aft. With the retainers broken, the slides seem to wedge the bars under pressure from the spring, which may fall out leaving the slide loose and rattling against the frame.
I've glued a small crossbar of wire to replace the other hinge spring retainers, and I think I'll just glue the two slides in position without the springs, whatever their function was is not clear, but I'm guessing some kind of whiplash inhibitor.
Hinge spring retained by a piece of wire hot glued in place of broken lugs. The slides were glued in and the springs discarded.
Reassemble, replace on seat and test.
Slides forward and back perfectly, no rattles while driving.
Both my headrests were rattling, with loose pieces inside. Car is C Class W205. I took out the driver's headrest fairly easily by sliding backrest back.
Then using flat wide screwdriver I carefully pushed the flaps out of the headrest cover back to reveal the inside plastic bit. There are 4 sides lets say, two shown below and two that open in the opposite direction
Showing first two flaps removed
I couldn't pop out the side button as described above, so again very carefully using plastic flat tool i moved the leather and the foam over the side button so it could slide out with the rest of the headrest.
Then i pulled the plastic headrest from its cover carefully so that the side button would not rip the foam inside.
Inside of the cover where the side button slipped out
Then unscrewed the two torx screws and voila the i side.
Two torx screws to unscrew. Pry open with flat screwdriver from the lower middle section
Loose plastic bits, two springs some broken bits.
I removed completely the broken small plastic bits and the single spring, and put back the two black covers with the two small springs.
Plastic covers reinstalled with springs inside. Bit tricky to set them correctly but dooable. Finally i now removed the sidebutton, from the inside by using flat screwdriver.
Side button removed.
Put everything back. Works great, no noise etc.
Still not sure what this spring was used for.
Left over bits
Left over bits
The little black bits help retain the coil springs against the black sliders, which appear to be some king of impact brake on the horizontal motion of the headrest. Can you still adjust your headrest fore and aft? Mine was jammed under pressure from one of these spring/slide assemblies, and without the small broken off pieces it was not possible to 'lock' them off the chrome bar under tension from the springs, so I left out the springs, and glued in the slider bars.
what I used was this video, it’s essentially the same thing. Pay attention to which flap to open first and which overlaps on what and reverse it back when reinstalling. GLHF!
Just do what you see in the video and you can pull the headrest right out.. Some also have a lock on the headrest to stop if from being removed to far.
I bent a nail, at either end, and was able to slip it in to where the clips had cracked off, and over the spring, that is never coming loose again.
Nail bent and inserted
Went in through gap from cracked off clip
JB weld in place
I also used some JB Weld to stick the broken pieces back in on the sprung retractor (not sure what else to call it), I think that these springs help the headrest go back in the event of an accident.
JB Weld reapir
The other, good, side
https://cimg0.ibsrv.net/gimg/www.mbw...f7d526373e.png
https://cimg2.ibsrv.net/gimg/www.mbw...e32244127f.png
https://cimg4.ibsrv.net/gimg/www.mbw...f63acb4458.png
JB weld in place
https://cimg1.ibsrv.net/gimg/www.mbw...f824386b72.png
JB Weld reapir
https://cimg4.ibsrv.net/gimg/www.mbw...a36cf9fa3a.png
