How to remove rear bumper vents for AMG flics (W205 Sedan)
How do I remove the OEM rear bumper vents without removing the rear bumper? The closest tidbit of info I could find on this forum was to "use needle nose pliers and to pull up and out". Ummm yeah, tried that and no bueno. Hopefully someone here can be more helpful and descriptive!
What's that tool officially called? and did you just carefully pry the off (top to bottom) while trying to mind the paint? See image below...
if not, just use dental floss! I used dental floss and tucked them behind the top part of the plastic vent.
Once the floss is securely looped over the top, just pull.
All the best!
