OEM headlight conversion possible?
also do I have to go to the dealer to get it programmed or a different harness etc
Option 1) Buy an aftermarket LED Headlight. Pros) Plug & play, Cons) Expensive, Quality ???.
Option 2) Buy a genuine LED Headlight. Pros) Good quality, Cons) Expensive, A lot of work to do.
Option 3) Buy a LED bulb. Pros) Cheap ($50) and plug & play, Cons) Same exterior look.
For option 2), you need genuine LED headlights (1 left & 1 right) ($500 used ~ $2,000 new), headlight control modules if not included in the headlights you purchased (2 left & 2 right) ($400 +/-), 205-768C wiring harness(about $200 +/-), Variant coding to "code 631/632 (static LED)" ($150~) (Option 1: Visit dealership, Option 2: Visit indy, Option 3: DIY (Xentry software, MB C4/C5 multiplexer, Windows labtop, MB SCN Login ID (rent onetime for $40 +/-), Knowledge(how to use Xentry software)).
Buy from a seller that has a > 90% rating, sold > 2 product and has received good reviews on that product and service. You should be fine.
Here are two different styles of W205 led headlights:
2015 style
https://www.aliexpress.com/item/32898065133.html
2019 style
https://www.aliexpress.com/item/4000616340776.html
https://www.aliexpress.com/item/4000608220177.html
https://www.lasfit.com/products/2011...-bulbs-package
