Help how to install LED turbo air vent for Mercedes Benz W205 C
Old Jan 29, 2020 | 02:09 PM
pablitoito's Avatar
MERCEDES CLASE C 220 W205
Hi, I want to install led aerators in my class c w205 and I don't know how to do it, has anyone done it? Does anyone have a tutotial or something to indicate how to do it and where to connect it?
Old Jan 29, 2020 | 02:34 PM
GringoBling's Avatar
C400
take the old ones out put the new ones in
the center console comes out, the vents are screwed to the back of it
if you need power for your LED's, you can tap the 12v outlet in the same panel
Old Jan 29, 2020 | 06:44 PM
pablitoito's Avatar
ok thank you very much for your answer. Do you have them mounted? Wouldn't you have instructions on how to do it?
Are the central console aerators screwed behind? is that those of the extremes apparently have to be pulled with a tool.
The 12v connection I do not understand where I have to take it.
Old Jan 30, 2020 | 01:25 PM
C400
I don't have those vents but I have disassembled the console and added the factory fiber optic tubes myself
look at the used center consoles for sale on ebay, find one with good pics of the back you can see what I mean. It's easy.
Old Jan 30, 2020 | 01:41 PM
pablitoito's Avatar
[CITA = GringoBling; 7967675] No tengo esos respiraderos, pero desarmé la consola y agregué los tubos de fibra óptica de fábrica.
Mire las consolas centrales usadas en venta en eBay, encuentre una con buenas fotos de la parte posterior que pueda ver. lo que quiero decir. Es fácil. [/ CITA]
Si si ya tengo instalada las luces en la consola central, lo que quiero es que alguien me ayude en la instalacion de las turbinas de aire acondicionado con led
Old Jan 30, 2020 | 07:11 PM
C400
Solo saca los viejos y pon los nuevos.!
Old Jan 31, 2020 | 06:47 AM
pablitoito's Avatar
And how do I get them and where do I connect them and where?
Old Jan 31, 2020 | 01:26 PM
C400
oh I thought you already had them!
ebay or AliExpress. They just click in, and they have wires that you run to a 12v power supply usually the back of the cigarette lighter
Old Jan 31, 2020 | 05:33 PM
pablitoito's Avatar
[CITA = GringoBling; 7968658] ¡Oh, pensé que ya los tenías!
eBay o AliExpress. Simplemente hacen clic y tienen cables que se conectan a una fuente de alimentación de 12v, generalmente en la parte posterior del encendedor [/ QUOTE]
Thank you very much for your answer, the problem that I don't know where to take power to work
Old Jan 31, 2020 | 06:29 PM
C400
the two wires off the cigarette light I told you this.
Old Feb 1, 2020 | 05:32 PM
pablitoito's Avatar
Ok, thank you very much for your response, the problem is that I don't have a cigarette lighter in the back.
Old Feb 2, 2020 | 10:52 AM
Mr. J's Avatar
C450, GLC43
You should still have 12v in the console. You might be better served if you go to a local car stereo store and get them to install this for you.
Old Feb 2, 2020 | 04:36 PM
pablitoito's Avatar
[CITA = Mr. J; 7970039] Aún debe tener 12v en la consola. Puede que le sirva mejor si va a una tienda local de equipos de música para automóviles y consigue que lo instalen por usted.
pablitoito's Avatar
It is an option, but I would like to try to install it first on my own and if I cannot go to a workshop. If anyone knows and can help me I would like to install it myself.
Old Feb 3, 2020 | 12:22 PM
C400
yes you do
Old Feb 5, 2020 | 10:21 AM
pablitoito's Avatar
yes you do
Alguien me puede ayudar con la instalación ?
