Keyed Benz😢
Old Feb 17, 2020 | 10:25 PM
BrittanyBenz's Avatar
c300 4matic
Keyed Benz😢
So someone or something keyed my trunk and I’m trying to figure the best way to fix this scratch WITHOUT going through insurance. Is there any at home solutions I can do that’ll get my car looking back to normal??
Old Feb 17, 2020 | 10:43 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Body shop
Old Feb 17, 2020 | 10:48 PM
Tirgoman's Avatar
2023 AMG EQE 53
Couple of things, go to the dealers body shop and do 2 things, ask then to tell you if it's just into the clear coat or all the way to the primer, can't tell from the photo, second get an estimate, if it's less or at about your deductible then just pay for the work yourself. If much more that's why you pay for insurance. One last idea, if it's just into the clear coat it sometimes looks white, if so done polishing compound and carefully work will get rid of it.
Old Feb 17, 2020 | 10:55 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Depends how deep
If it’s deep and you don’t know how to fix it take it to a shop shouldn’t cost too much.
if it’s not u can buff it out $10-$20 DIY
Old Feb 18, 2020 | 11:23 AM
MariTheBoss's Avatar
2015 C300 4MATIC / 2017 C43 AMG
Sorry to be the bringer of bad news- that looks bad. If you take your nail and run it perpendicular to the scratch and you feel it, it probably has significant damage. Some insurance policies have vandalism coverage (0 deductible), and if you have comprehensive coverage, your deductible would (probably) be significantly less than the cost to prep and paint the full deck lid. Sorry this happened- some people are haters, some people hate what you have and how you got it. Keep ur head up and get it fixed right the first time
Old Feb 18, 2020 | 11:47 AM
Shoaib R. Manai's Avatar
Mercedes C300 2015
So couple of things. Run you finger nail in the scratch, if it catches then the scratch has gone all the way through the primer in that case you would need to go a body shop to get it repainted. If doesn't catch on then it probably is a clear coat damage. You can DIY that by using a compound to flatten out the clear coat using a DA polisher and then finishing it off with a polish.
Old Feb 18, 2020 | 12:04 PM
GringoBling's Avatar
C400
that's not buffing out
wetsand maybe, but a shop wouldn't charge much to fix it
Old Feb 18, 2020 | 12:46 PM
Tirgoman's Avatar
2023 AMG EQE 53
Above is good advise except that even a slight scratch into the clearcoat will catch your fingernail, depends how deep, so don't skip a heartbeat at that. Having said that it does look bad and down to the primer in the pic.
Old Feb 18, 2020 | 02:47 PM
Camaroguy72's Avatar
2019 GLC300, 2017 E300
You could try touch up paint , find a used trunk lid and have it swapped , or get it repainted. Looks through the clear so buffing won’t work. Probably a $500 -$700 job at a body shop to repaint if there’s no other damage would be my guess.
Old Feb 19, 2020 | 01:39 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Who did you **** off at work?
After you get it fixed, invest in a hardwired two channel HD daah camera. Maybe run it off a cellink neo battery backup so you don't kill your main battery and get 24 hour motion recording.
You may one day catch the culprit in the act and get your repair costs back, after court.
Old Feb 19, 2020 | 06:18 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Well, the shop I usually use would estimate that at around $1,200 or so. Sorry, but to do it as well as possible, they need to not only block sand that deck lid, repaint color, then repaint clear, AND they will need to blend into both rear fenders to ensure that the color and texture look exactly the same from the trunk to the fenders. That's the only way I would accept the job.
If somebody says they can paint just the deck lid, run. . . it won't match from all angles, and you will see it. The mis-match will make you crazy.
Old Feb 19, 2020 | 07:55 PM
This; the cost of prep, materials, and labor for repainting the deck lid is not a little job to mickey mouse around with. Imagine the absolute butcher job some are suggesting- touch up paint? My god. Seriously, call your insurance, ask about your coverage and options, and go from there. They will guide you, be able to have a shop provide an estimate, and you can choose to go through insurance or not at that point.
Old Feb 19, 2020 | 08:54 PM
dwpc's Avatar
2017 C300 Cab 4Matic
It looks deep, meaning it needs to be sanded, filled, primed and the entire trunk lid resprayed. $$$ or a project of self-taught auto paint repair.
Old Feb 19, 2020 | 08:58 PM
dwpc's Avatar
It looks like a deep gouge, meaning it needs to be sanded, filled, primed and the trunk lid resprayed. $$$ or a you could use it to learn DIY auto paint repair.. It may as well have been hit with a hammer.
