W205 7spd Long 1st Gear
Old Jul 7, 2020 | 11:18 AM
Bmarcinczyk14's Avatar
2016 C300 w/ sport package
Does anyone else notice their w205 holds onto 1st gear sometimes past 3k rpm before shifting into 2nd and then shifts into 3rd like almost instantly? This is when accelerating lightly, I really wish the car would shift out of 1st a lot sooner than it does, unnecessary wear and gas when you're not even accelerating hard. The shift points on this car makes no sense to me. Sometimes I can get it to shift out of 1st at a reasonable time if I accelerate a little harder but how does that even make any sense? I feel like there should be a software update to fix this issue but I mentioned it to my dealer and they just said everything looks normal.
Old Jul 7, 2020 | 07:12 PM
tyabnet's Avatar
2000 C230 - 2001 E430 - 2003 E320 -
What mode are you in - Economy, Comfort, Sport, Sport+? Try changing the mode...
Old Jul 7, 2020 | 07:45 PM
fabbrisd1's Avatar
A gaggle of MB's
In Economy and Comfort - normal takeoff from a stop is 2nd I believe.
You might download a pdf copy of the 2016 C300 Owner's Manual from MBUSA.com - click My Account upper left corner of that Home Page - then click Owner's Support - in Owner's Support scroll down to View Manuals - in View Manual move slider to right to 2016 - open and download your manual
Old Jul 7, 2020 | 07:47 PM
I'm in comfort, mode makes no difference....
Old Jul 7, 2020 | 07:49 PM
The car starts in 1st gear from a stop all the time.
Old Jul 7, 2020 | 08:12 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
it starts in first in both economy and comfort.
Old Jul 7, 2020 | 08:13 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Would resetting the transmission fix it this?
Old Jul 7, 2020 | 10:39 PM
No clue, and is that something you can do yourself?
Old Jul 7, 2020 | 11:07 PM
irondad's Avatar
W205, X253, C190, W213,
My car (2020 9-speed) definitely starts in second in Eco and Comfort and first in Sport and Sport+.
Old Jul 7, 2020 | 11:11 PM
That's because the car we're talking about is a 2016 which is a 7 speed, completely different transmission which always starts in 1st.
Old Jul 7, 2020 | 11:14 PM
irondad's Avatar
TIL
Old Jul 8, 2020 | 02:25 AM
matt.jessop's Avatar
C200
I have noticed this on my 2018 C200 every now and then, doesnt matter which mode I am in (usually Eco or Comfort). It doesnt happen very often and I find lifting off the gas usually forces it to go up the gears.
It doesnt happen enough for me to mention it to the dealer but I will do if it starts happening more than it does.
Old Jul 8, 2020 | 02:26 AM
C200
I am so envious of the digital dash
Old Jul 8, 2020 | 12:58 PM
stockbmw's Avatar
2018 C43
Reset your transmission like others suggested. I regularly reset my transmission when it goes to 2k rpm when I lightly press the gas in comfort mode.
1. Turn the key to position 2. You should see all the dash lights come on. Don't start the car. In position 2, you should hear two clicks and all your dash lights should turn on. Do not start the engine.
2. Press the gas pedal all the way. By pressing the accelerator pedal to the floor, you will activate the kick down switch. Keep the gas pedal pressed all the way to down.
​​​​​3. Wait. Continue to keep the gas pedal pressed for at least 10 seconds.
4. Turn key to OFF, position 0. Don’t remove the key.
5. Release the gas pedal.
6. Wait 2 minutes. During this process, key is left in the ignition in the OFF position.
7. Start the car and drive.
Old Jul 8, 2020 | 01:39 PM
My car is a push start, still same process?
Old Jul 8, 2020 | 08:01 PM
GreekUPS's Avatar
Does your push button not come off? Either way it’s the same.
Old Jul 8, 2020 | 08:06 PM
I tried it and after a quick test drive it seems to still have that holding the revs in 1st too long issue.
Old Jul 8, 2020 | 08:52 PM
stockbmw's Avatar
2018 C43
Do it few times, there might be chance you missed a step. I just did it again on my car and it stop going to 2000rpm but 1500rpm then upshifts when lightly pressing the gas.
Old Jul 8, 2020 | 08:56 PM
After step 6 is it a requirement you start the car? Or can you pull the key out and leave the car?
Old Jul 9, 2020 | 12:51 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
722.9 Transmissions start in 2nd gear when in comfort and eco. 1st gear in sport.
Old Jul 9, 2020 | 09:29 AM
Not sure what the 722.9 Transmission is, all I know is I more than likely do not have one as mine starts in 1st gear from a stop. If you don't completely stop many times it will stay in 2nd, but from a dead stop always 1st gear. It would be nice if it did start in 2nd I can tell you that much.
Old Jul 9, 2020 | 04:14 PM
stockbmw's Avatar
2018 C43
Also, check if your AC is on. Best turn it off by making sure AC REST and AUTO climate are not lit.
When AC is on, your car will rev 500 rpm more before upshifting.
Old Jul 12, 2020 | 01:55 PM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
Welcome to the club! I have complained to the dealer countless times because of the exact same issue. They did re-adaptation a couple of times and software updates, but it didn't help. After test driving several model years I came to realize that Benz introduced a change in the transmission software mid 2016. Anything built before shifts fine. Anything built after shifts like... well, you already know.
I have posted videos on youtube about the issue:
Ask a Mercedes indy shop to check for a software update for your transmission. Don't trust the dealership!
I believe the real issue has something to do with the acceleration and timing. If you keep gradually depressing the acceleration more and more for over 0.7 seconds then you got the long 1st gear. Try depressing it quickly to your desired point within 0.5 sec and hold it there and the transmission will shift fine.
Also, if you accelerate to about 1.100-1.200 rpm then hold it there for about one second then accelerate again the transmission will shift fine.
It's weird to say the least...
I ended up trading the car in for a new one with the 9G transmission. I just couldn't take the crappy shifting anymore.
Old Jul 12, 2020 | 06:44 PM
https://youtu.be/0Iqvzv00ZNY
​​https://youtu.be/P2oTpW4vU7o
Yes that's EXACTLY what I'm talking about! It's nice to see this is a common thing with these cars and not just with mine. I'll give the acceleration thing u mentioned a shot and see if it shifts better. I feel like ever since the reset procedure I did its shifting better but hopefully it really fixed something and not just luck lol.
Old Jul 12, 2020 | 08:00 PM
blizzard12's Avatar
While hard(er) accelerations may fix your shifting pattern they put a strain on the whole powertrain from the engine to the tires. That's why I don't recommend them on the long term.
I don't know your location, but there is a place in the GTA that have helped other people with this issue.
Unfortunately I only found them after I traded in my 2017 C300.
