Brake pads front and rear
Old Jul 15, 2020 | 07:14 AM
feebabii's Avatar
2017 c300
Any suggestions on brake pads. Are OEM required or can we use any brakes that fit the car? Does any one have suggestions on brake pads front and rear that aren’t OEM? 2017 C300 4matic. Thanks in advance!
Old Jul 17, 2020 | 04:00 PM
feebabii's Avatar
2017 c300
Help
Old Jul 17, 2020 | 06:54 PM
mikec35's Avatar
2016 C300 sedan
I’d use factory pads. I’m at 127,000 miles, still using the original pads. With that kind of track record I wouldn’t change a thing.
Old Jul 17, 2020 | 09:09 PM
feebabii's Avatar
2017 c300
Thanks mike im at 30k miles and check brake wear light came on and I barely drive it which is weird
Old Jul 17, 2020 | 09:26 PM
mikec35's Avatar
2016 C300 sedan
Check your brake fluid level. That’s not enough miles for the pads to be worn out unless the car is driven hard or on a lot of mountainous/curvy roads.
Old Jul 17, 2020 | 09:32 PM
feebabii's Avatar
2017 c300
That’s what I was saying and it isn’t driven on mountain type roads at all. I only drive on weekends really
Old Jul 17, 2020 | 10:44 PM
CW3SF's Avatar
AMG GLC63/Jag F-Type/SQ5/ZL1
I’m running EBC Reds. No dust, no squeal and stops like OEM.
Best mod I have done to the car.
Old Jul 18, 2020 | 12:28 AM
GringoBling's Avatar
C400
you can use whatever you want, they're just Brembos. Brake pad change takes about 10 minutes per wheel, you just hammer two pins out and they fall out.
Old Jul 18, 2020 | 12:49 AM
Gazwould's Avatar
S204 C250 CDI Sport
Yep , got full sets on 3 cars , OE when cold , get some heat into them then it's a performance advantage.
Ferodo Eco Friction is ment to be OEM .
Old Jul 18, 2020 | 09:48 AM
feebabii's Avatar
2017 c300
Definitely looking into them now
