2017 W205 C300 Creaking behind dashboard
Apart from the tires and alignment, I now have a constant creaking sound that seems to come from behind the dashboard as I am driving. I suspect that it is coming from behind the center console. I have attached a video of me driving the car today wherein you can clearly hear the sound. After much investigating with the service department at the dealership that sold me the car, the sound appears to be coming from inside and is not related to the suspension or wheel-bearing. I am going to bring this to Mercedes to diagnose being that I am still under warranty; however, I wanted to pick your respective brains as to what you think this might be attributed to so that I can steer Mercedes in the right direction (no pun intended).
The issue in my situation was that the independent dealership shop did a half-*** installation job and also did not replace the strut mounts (they failed to mention that fact) because their “interpretation” of what their obligations were did not require them to do so. I could not figure out what the noise was since I had assumed they had replaced the mounts, but after realizing the noise was not coming from the control arm but rather the strut mount rubbing against strut assembly due to the top center nut on the passenger side not being properly seated. I had the mount where the sound emanated replaced by my mechanic (at my cost so that the job was done right) and the problem was resolved.
front OEM strut mounts don’t cost much - little over $100. Should you have to replace them, you won’t break the bank.
At the time, the labor and the part combined came out to $400 USD at an independent repair shop. Mercedes Dealership wanted to replace the entire frontend.
And to all the naysayers, this car lasted me until January of this year (2025). Unfortunately, while the car was parked outside overnight, a garbage truck slammed into it and totaled it. Apart from that, this car was driving great and had no major issues. I was close to going over 100k miles
