Sqeaky noise from the steering wheel and a quote from MB
Old Feb 7, 2021 | 06:00 PM
Jonnythedent's Avatar
c class 2015
Hi nice people.
my c class recently developed a noise when turning the steering wheel.
Visited MB garage and they said a lower shaft of steering wheel would need to be changed and quoted £500! (Inc labor, part and 2-yr warranty).
Is this a fair price and would it really need to be replaced?
Video link is attached below for your advice too.
Thank you
Old Feb 8, 2021 | 02:31 PM
chrisdean's Avatar
W205 C200 AMG Line Premium
The noise isn't actually coming from the steering wheel even though it may sound like, it comes from where the steering column runs through a rubber bush or similar in the engine bay. A copious amount of WD40 squirted down the steering column should fix it. Did you find that the noise only started as the weather got colder?
Old Feb 8, 2021 | 05:58 PM
2014CL600's Avatar
Cars
My S Coupe is doing the same thing, What was wrong and did you fix it? Have an extended warranty but I bet they wouldn't cover it if it's a rubber bushing
Old Feb 8, 2021 | 08:39 PM
pkaia524's Avatar
2015 C300 4Matic, 2014 Porsche Cayman, 2017 Porsche Macan
I have a similar sound, and yes it is temperature related.
Which side of the firewall are you suggesting as the place to start with WD-40?
Old Feb 9, 2021 | 01:13 PM
chrisdean's Avatar
The engine bay, just spray liberally on as much of the steering column as you can see and turn the wheel lock to lock when you've finished.
Old Feb 17, 2021 | 07:51 PM
Mbinco's Avatar
W205
Have exactly this issue, presumably due to lack of use during covid/lockdown.
Did you manage to resolve it? Is it possible to access the right part from the engine bay from above or is a pit/ramp needed? Would be awesome to have a photo!
Is standard wd40 the best thing for this or would something like lithium grease be better/last longer?
It's so annoying when the dealer/garage jumps straight to replacing parts that probably won't even solve this, yet i bet if you'd just driven off the forecourt with an approved used that started squeaking they'd spend the 5 seconds to grease it up and send you on your way!
Old Feb 18, 2021 | 08:38 AM
chrisdean's Avatar
WD40 was all I had to hand. Starting at the bulkhead locate the steering column and spray generously with a lubricant and follow it down, it will eventually work its way in if you turn the steering wheel a few times.
Old Feb 18, 2021 | 06:12 PM
Mbinco's Avatar
W205
Thanks Chris. I'm thinking of using this:
https://wd40.co.uk/product/high-perf...one-lubricant/
Seems the problem with a grease is trying to get it to run into the parts that need lubricating so a spray is needed. That being said, I'm wondering if this may fair a bit better than standard wd40?
Cheers!
Old Feb 18, 2021 | 06:19 PM
PaulR7's Avatar
W205
Seems the problem with a grease is trying to get it to run into the parts that need lubricating so a spray is needed. Wondering if this may fair a bit better than standard wd40?
That should be pretty good, I used it on my folding mirrors and they've been squeak and jerk free.
